Question about SkyScan 86709 Atomic Wall Clock
I have 3 clocks w/ Temperature Transmitter 4.33MHz,all have quit
I have replaced the batteries in the proper sequence...not one of the 3 will work. Seems the clocks are fine.
Thanks,
Judi McLamb
dlmclamb@gmail.com
  • Anonymous Jan 05, 2009
    Temp not working in both our Sky Scan clocks, they both went on the fritz just about the same time.
jerryg50
  • 1689 Answers
SOURCE: Out side temperature reading
Without having parts to try, this would be difficult to know what the fault is. Inside this unit there is a circuit board, and on the outside there is the exernal temperature sensor.
There are only a few things that can go wrong. There is not much that is servicable unless you can find a spare board, or a spare temperture probe. There is very little posiblity that in any practicality this unit can be serviced at the component level.
I would just go out and buy a new unit.
Jerry G.
Posted on Apr 21, 2008
  • 7 Answers
SOURCE: outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Posted on Dec 19, 2008
SOURCE: Temperature Transmitter
I have already try putting in new batteries and taken out of the clock and the trasmitter and still dont work what can i do now its a SioScan Temperature Transmitter 433 MHz
Posted on Sep 19, 2009
SOURCE: my clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Posted on Nov 23, 2009
  • 10865 Answers
SOURCE: Outside temperature not working on
hello lucy... you most likely have some corrosion in the outdoor component. Remove the batteries from the outdoor component and clean the battery contacts with the eraser end of a common pencil. Reinstall the batteries and then give it up to 8 hours to start reporting accurately again. Joe
Thanks for choosing Fixya!
Posted on Feb 18, 2011
How to fix clock
I have a similar unit, the batteries in the display unit only last 4 to 6 months. The ones in the transmitter last over a year. Replace the batteries in both, and write down the date. The next time the outside temperature doesn't display, just change the display unit battery and again keep a note of the date. I buy CR2032 button batteries in packs of 10 from www.batterybuyer.com
Jul 06, 2018 | Home
This type of device requires battery installation in the transmitter first, then a brief wait for the transmitter to begin sending temperature data. Once the transmitter begis sending data, install batteries in the "receiver" and check for temperature display.
Nov 01, 2014 | Home
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
The wireless transmitter doesn't work
Mine quits working when the batteries in the outdoor part need changed .
Dec 15, 2017 | Centrios Audio Players & Recorders
I have an acurite atomic wall / weather clock but the outside temperature is reading blank. I changed the batteries in the transmitter but still no reading. Where can I purchase a new transmitter. The...
I had one of these a while back and it had a required sequence for putting in the batteries. When the signal dies and you have to replace the transmitter batteries and the clock batteries in a certain sequence. The transmitter batteries cannot just be replaced. You also had to remove the clock batteries, then put in the transmitter batteries, then replace the clock batteries.
Dec 03, 2010 | SkyScan 86742 Digital Atomic Wall Clock
The clock stopped showing the outside temperature. Replacing the batteries on the transmitter has not solved the problem. Suggestions?
OFTEN you must re-sync the receiver with the transmitter in these units. Refer to the manual for startup sequence.
Apr 26, 2010 | SkyScan 86709 Atomic Wall Clock
We replaced the batteries on our SIO SCAN temp transmitter but it still will not register the outside temperature--what do I do?
Take the batteries out of the clock AND the temp transmitter. Wait about a minute, then replace the clock batteries. Wait another minute, then replace the transmitter batteries. Once the clock synchronizes with the satellite, you will need to set the time zone and whether you want DST on or off.
Dec 08, 2009 | SkyScan 86709 Atomic Wall Clock
My clock is nort showing up the outside tempertute
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
Outside temperature won't work
Also,
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
SkyScan 86709 Atomic Wall Clock Logo
116 people viewed this question
Top SkyScan Home Experts
Steve Allison
Steve Allison
Are you a SkyScan Home Expert? Answer questions, earn points and help others
