Question about Mitsubishi Diamond Pro 900U 19" CRT Monitor
Ocassional flickering I love this monitor. However, just recently... this past weekend the monitor will flicker about 4 to 5 times a day. It will only flicker once then it will work fine for a while then it will flicker again. I really hope this isn't a sign that this thing is dying. I've had a new computer since August '06 and this monitor has been woking fine with it until just the other day. Any thoughts.....?
  • lemongas Mar 03, 2008
    It has slowly got worse, which is why have been on the net looking for a problem, at start up today, the monitor would keep refreshing every few seconds so that nothing could be done until it had stopped. It now still does this maybe every half hour: the screen goes blank, there is a tick sound and then the screen reappears.
  • Anonymous Oct 17, 2008
    Same tick monitor is dead now.
Not sure what the problem is, but am experiencing the same symptoms every few minutes on a Mitsu Diamond Pro 91TXM, just retrieved from storage after 7 years. How's your screen holding up since April?
Posted on Sep 20, 2007
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
My campaq desktop monitor 7540 is flickering horizontal direction
Try a different CRT monitor on your computer.
Try your CRT monitor on a different computer.
See if the problem "moves" to the other computer,
or whether your computer has problems with *ANY* monitor.
Dec 27, 2013 | HP COMPAQ 7540 CRT Monitor
My monitor compaq model MV520 is always blinking every time I open my computer, How can I fix it?.
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to answer and solve your problem. Your Compaq MV520 Monitor is always blinking every time you turn on your computer and you want to know how you can fix it? First, we need to troubleshoot the problem. I'm thinking you probably need to refresh the flicker rate on your monitor. The flicker rate is probably set on a low setting, which is causing you screen to blink (flicker). This can be bad for your health as well because it can cause eyestrain and headaches. Your monitor is a CRT (Cathode-Ray Tube) model. These types of monitors can cause a lot of screen flickering. Now that we've troubleshooted the problem, now it's time to solve the problem. There are two ways you can solve this problem. You can either refresh the flicker rate or you can buy an LCD monitor. LCD monitors flicker-free. My suggestion is that you refresh the screen flicker rate. To refresh the flicker rate, go into your System Preferences or Control Panel, click your operating system's appearance and display link and click your screen adjustment link. You may have to click your advanced settings link. Click your monitor tab and from there adjust you screen refresh rate. You may have to adjust your screen resolution before you refresh the screen rate. If you have to do this, make sure the screen resolution you choose supports you monitor's height and width as well as visibility. The higher the resolution, the higher the screen rate. The instructions I'm giving you may sound like this because I'm not sure what your operating system is. I'm not to familiar with Mac Operating Systems, but if you have a Windows Operating System and you need better detailed instructions, just reply back. I hope this decreases your screen flickering and gives you a better viewing experience.
Jul 07, 2011 | Computers & Internet
My monitor has been flickering from switch on for about a month. After re-starting 3-4 times it would clear. Then it took up to 8 times then it is just sometimes blank when I switch on. When it is plugged...
its power to the pixels causing the flickering the eletronics controlling which to use may be on its last legs,sorry but it sounds terminal for its use
Jun 22, 2010 | Samsung 226BW Monitor
Hi, my monitor started to flicker 3times/second persistantly.
its the monitor its the main board may stuff up tomorrow may stuff up next week or in a years time hard to day as its only flickering take in for a check up
Apr 04, 2009 | LG FLATRON L1970HR LCD Monitor
Monitor flickers unless brightness is at 100%
Try monitor menu select Memory Recall and press that, should clear right up
Mar 08, 2009 | ViewSonic VA1912wb Monitor
Flickering screen
If you bought it new in this last August, don't put up with it but get it fixed under the warranty. That is what warranties are for.
Jan 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor screen shaking and flickering
Check to make sure the cables are connected tightly. Wiggle the cable, does it get better or worse? Might need a new cable. And reseat the video card inside the computer. If that doesn't fix it, then yes you will probably need a new monitor.
Jan 15, 2009 | Acer AL1917W LCD Monitor
Blueish flickering
Try to put speaker distance from monitor.
Try to remove the display card and fixed it again.
Then boot up your and see .
Apr 21, 2008 | Acer AL1913 19" LCD Monitor
Monitor started to flicker then went blank
I have a envision professional series and I love it, but I will get to the point.
I recent ly received a Envision EN9410e monitor, had the same problem (flickering screen then turned on, then off then on then blank). The problem is bad capacitors. There are 7 electrolytic capXon capacitors that will need to be replaced. You should see if the caps are bulging or leaking, if so replace. As known by many replace with the same capacitance and voltage. There are a few incidences that the capacitors where replaced and the problem wasn’t solved; this is because the cap problem wasn’t taken care of and damage occurred to another part of the monitor. The back light is a Royer oscillator (cool things) and it uses two smd mosfet transistors. They are on the green side of the circuit board near a big control chip (they each look like a off rectangle black square with eight pins) you need to see if there is any carbon or chard residue between the pins or burning smell from them, if there is you need to remove the transistor and do some board repair then ether put a new transistor or try the old one. No offence to the people at Envision but not smart putting the drain, gate and source so close to each other under the chip where there is such high voltage! Hope this helps.
Dec 24, 2007 | Computers & Internet
Mitsubishi Diamond Pro 900U 19" CRT Monitor Logo
176 people viewed this question
Top Mitsubishi Computers & Internet Experts
Shaukat Bhutto
Level 1 Expert
Alun Cox
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
