Gateway Toshiba DVDR/RW TS-h552 will not open and DOES NOT HAVE SMALL PIN HOLE at front to use for manual opening. I have tried to remove the curved plastic front cover. There are 4 plastic latches - two on the bottom and two on the side - but when they are depressed something is still keeping the front cover in place on the lower part of the drive.
  • bdalzell Dec 21, 2008
    I already have it out of the machine and I have removed the four screws holding the top of the dvd box to the dvd case. I can see the circuit board and the internal cables. however I cannot find anything that seems to be a release for the drawer. There is a black rachet extending along the long axis of the internal part of the drive but nothing that responds to gentle probing to release the drawer from the enclosing box.I was hoping I could get the plastic front piece off the box - there are 4 plastic tabs tabbing into the case - two on top and two on the side that seem to hold the front piece but when I depress them there is still something locking the frontpiece in place that is on the bottom side of the metal box. I am afraid to force the front off as I do not want to break some important plastic tab. I have looked online to try and find a manual for this thing but neither the gateway nor the Toshiba site was usefule. what i cannot understand is why there is no release pin hole on the front which is the standard for most dvd and cd drives.
    is there a way I can send you images of the unmounted drive?
    President:
  • 2,110 Answers
  1. Close all programs and shut down the PC.
  2. Unplug the power cord from the power outlet.
  3. Look for the small hole on the faceplate of the CD or DVD drive. Thisis the manual release. The location of the manual release hole willvary (see Figures below for possible locations).
    NOTE: Onsome models it may be necessary to remove the front panel to expose themanual release hole. Check the documentation that came with your PC forinformation about removing the front panel.Gateway Toshiba DVDR/RW TS-h552 will - c00366523.gif
    NOTE: Onsome models the release hole and the drive activity LED look similarand are about the same size. Do not force the paperclip into the holeif it does not go in. Make sure that the hole is not actually the LED. Figure 1: Possible location of manual release hole c00366142.gif Figure 2: Possible location of manual release hole Gateway Toshiba DVDR/RW TS-h552 will - c00366143.gif c00366143.gif Figure 3: Possible loGateway Toshiba DVDR/RW TS-h552 will - c00366144.gifual release hole c00366144.gif
  4. Straighten the paperclip and insert it into the manual release hole until resistance is felt.
  5. Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
  6. Remove the paper clip and gently pull out the drawer until the disc is accessible.
  7. Remove the CD and turn on the PC.
Posted on Dec 21, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, for some reason the model TS-H552 shows a Samsung DVD drive. In any case, the front cover could not be removed not unless the tray cover is removed first.
In the absence of a pinhole, the tray cover could not be removed without breaking it. The alternative is to remove the cover of the drive itself and exposing the internal mechanism. Thereafter, the gears must be manually turned to initiate the tray lock/latch and continued to partially eject the tray. Should this be accomplished, then tray could be manually pulled out. Often causes of this problem is a loose or broken belt or in some instances a defective loading motor.
Good luck and Thank you for using FixYa. Happy Holidays.
    President:
  • 1,179 Answers
You can try removing the drive then open it up by removing the screws. Once opened you should be able to see what is causing the hangup and repair accordingly. Do not attempt to force open as it will only break. Hope this helps you.
    Master:
  • 479 Answers
Remove whole device and try opening it totally with a screwdriver its not at all hard to get it opened just screws and nothing to open to open it completely.
Cd rom wont open
Hi in front of the CD-ROM drive there should be a small pin size hole. Stick a pin in there to release the CD-ROM lock and it should open.
Jun 12, 2012 | Toshiba Samsung Slot Loading DVD+RW Slim...
My DVD/CDW-ROM drive is gone! It is a TSSTcorp TS-H552D How can I down load a new driver free?
Try the following link;
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
If that doesn't work I suggest you install a free program called "Slim Drivers" and allow it to scan your system and locate the correct driver. I recommend noting which drivers you're installing so they can be rolled back should one of them not function properly.
http://download.cnet.com/SlimDrivers/3000-18513_4-75279940.html
Feb 19, 2011 | Gateway GT5408 PC Desktop
Dvd stuck open. Compaq Presario SR5505F Desktop PC
you can open it by using 1mm pin....check the front of DVD panel and you will see a tiny hole near the button...insert the pin and push until the DVD discard...
May 24, 2010 | Samsung TS-H653F DVD±RW Dual Layer Burner
My Toshiba ts-h653 cd/dvd RW drive failed w/DVD inside
ur desktop needs to be open at all cost otherwise no solution
Nov 30, 2017 | Computers & Internet
My Toshiba ts-h653 cd/dvd RW drive failed. the
If the drive is trashed, just force the drawer open. If you don't want to do that, you should be able to disassemble the drive enough to get the disk out by removing screws... Sometimes the screws are underneath stickers, or warranty stickers, etc etc.
May 09, 2010 | HP Computers & Internet
I CANNOT OPEN MY DVD DRIVER ON MY TOSHIBA NOTE BOOK
I have never worked with a toshiba notebook.However every DVD/CD driver has a small pin sized hole on the front of it .This hole is sort of a manual switch.If getting the drive open is urgent, insert a pin in the hole and press gently, the drive should pop open.Get your drive checked though.Most likely it's the motor which has failed.Within warranty periods it's a free replacement.
Dec 31, 2009 | Toshiba Satellite A100-S8111TD Notebook
My disc drive wont open, i tryed hitting it, prying, and even tearing off the front off my tower! any ideas?
in front of your cd rom disc drive you will see a very small hole, try to insert a small sharp object or pin that will fit in the hole, that is the bypass key to open the disk tray
Nov 14, 2009 | Gateway GT4016 Desktop PC
Dvd rw drive does notrespond to eject command
this is common there is a small pin hole front left corner bend a paper clip straight and insert in the hole the door will open about 1 inch long to go in
Aug 22, 2009 | eMachines ET1161-01 PC Desktop
A dvd was inserted into my toshiba qosmio right before it broke, and is due back to video store, is there a manual way to remove it?
The dvd drives usually have a small hole on the front. Carefully push the end of a paper clip into the hole and the platter should eject.
Jul 29, 2009 | Toshiba Qosmio G25-AV513 Notebook
DVDR 3350H KEEP READING AND WON'T EJECT DISC
Look under the faceplate where the disc tray ejects and see if there is a small hole. If so, use a straightened paper clip to eject the disc manually by pushing it into the hole about an inch. If that works, then reset the power on the unit and try a nonrecorded type disc to see if the unit works at all.
Other than that, you'll have to take the unit apart to get your disc out.
Hope that helps...
Geno
Mar 24, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Computers & Internet Logo
358 people viewed this question
David Payne
David Payne
