Question about Maytag Neptune MDG5500AW Gas Dryer
Tumbling vane screw came out - other is loose, banging as clothes tumble - how do i pry(?) open the lid (top shell) to access the drum exterior?
  • Anonymous Dec 21, 2008
    One tumbling vane screw came out and rattled. The vane broke off from the second.
  • griedjam Dec 22, 2008
    I was too impatient to wait for resonse and was not sure if my question even went thru (internet problems) - I was able to finally get the problem solved and actually did all of RescueTech's steps w/ a bit of guesswork (I am a machine desinger by trade so that helped) His step-by-step solution is the best, most clear description I've seen in a long time. This response would have saved me time (and I did pry a little but only cracked enamel where it can't be seen) I put a drop of glue (plastic cement ) on the vane screws before reinstalling to prevent backout again (although I did not remove/replace the others) I also cleaned out as much of the lint as I could reach before replacing covers!
  • 145 Answers
Hi and welcome...
You don't want to pry on anything, that top is secured by hooks and you have to do some dis-assembly to get the top open.
1. Open the door and remove the two screws that secure each of the door hinges to the dryer frame. With the door open so you can take a hold of it, simply pull the whole door out of the notches that the hinges fit into. (This is a reversable door designed for easy removal by the customer)
2. Remove the two screws on the opposite side of the frame where the door closes to. (along with the two white plastic trim pieces the screws go thru)
3. Once the door is off and the screws are out, pull the entire front panel forward and then it will lift off the tabs at the bottom and you can set it aside.
4. Look up near the top of the cabinet, on each side, for the metal hooks that secure the top to the cabinet. Remove the screw (5/16" nut driver) that secures each hook to the cabinet. Take the hook off, repeat for the other side.
Lift top.
Hope that helps.
Posted on Dec 21, 2008
    President:
  • Maytag Master
  • 2,651 Answers
You can remove the doorhinge screws aswell as the 2 oppite the hing. then remove the u-shaped front panel, form there, there are 2 5/16 screws holding hte top cover to the main frame, remove those sand you should be able to tilt the cover back to acess the screws on the vanes
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
My kenmore dryer makes a loud rattling noise like it has belts with metal buckles tumbling around inside of it.
This happens when coins get inside the metal vanes that tumble the clothes inside the dyer. It can also happen if a belt wears off a strip of the belt that starts slapping the interior walls as it turns. A third way is for one or more of the the rear support rollers of the drum to become worn.
The first two causes can be checked by watching the first minute and 20 seconds to see how to raise the top of the machine. Be SURE to unplug the machine FIRST and not plug back in until FULLY assembled correctly.
Once top is raised turn tub very slowly clockwise (inspect belt for fraying as you turn) until screws show up that attach the inner vanes to the tub wall. Remove these screws to check the interior of the van inside the drum for foreign objects and remove. Complete one vane, reattach and move onto the next. If you don't find ANY objects in the vanes move on in the video to the 3 minute mark and you will see the 2 rear support rollers. Check them for wobbling or tightness and replace if necessary.
The Final Possibility could be a very wobbly idler pulley that needs to be replaced on the floor of the dryer. I have included a picture of the belt configuration if you need MORE disassembly than just the top.
How to Disassemble Whirlpool Kenmore Dryer http://www.applianceaid.com/images/belt-config.JPG
Nov 21, 2015 | Kenmore Dryers
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Ben wont turn turn on i can hear see fan spining wont tumble
It sounds to me like a belt drive that has failed.
You can check on the belt by lifting the lid on the top of
the unit. It should just pry up between the top cover and the
side. Stick a screw driver in the crack between the top and the side,
pry up, but be careful not to damage the paint. possibly use a clothe
to protect the screw driver edges.
Then lift up on the cover when it becomes loose to view the drum
and the belt to see if the belt is broken.
Thn you may be able to replace it yourself.
I f not, you will need to call a service repair man.
Feb 25, 2011 | Whirlpool Dryers
Inside the dryer there are 3 bars that stick out to help tumble the clothes. One of them has come loose and I'm not sure how to tighten it. It appears to be attached with screws that come thru the drum...
With the front off look up in the top left and right corners for some screws that hold the top of the dryer to the side panels. Depending on your model, there can be different styles. The old maytags used 3/8 in screws up inside the corners and the newer models had 5/16 screws right up front.
Once you get the front of the top loose you will be able to lift it like the hood on a car to gain access to the drum.
Rotate the drum by hand to put your loose fin at the top and tighten up your screws. Sometimes the screws will round out the holes on the drum too much and you may want to put a washer on the screw to secure it better.
Oct 07, 2010 | Maytag Dryers
One of the three things that tumble the laundry in the dryer is loose--it is making alot of noise--how do I tighten it
I think you are talking about the large ribs that prevent clothes from just sliding in the drum.
They are available as a spare, so are usually screwed in from outside the drum.
To fix your problem, turn off and unplug dryer.
Remove back pannel screws holding the lid on, and slide back the lid.
Rotate the drum by hand internally untill the faulty blade is at the top. You should be able to see the screws that need tightening.
Replace parts when finished.
Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the vanes inside my gas dryer is loose and makes a loud banging sound when the dryer runs. How can I tighten it?
depending on style dryer,you need to access drum.usually top will pop up and hinge back.rotate the drum by hand counter clockwise till your loose vane is on top,you should see screws or maybe a missing one .add flat washers to secure better.If the plastic threads are broken/stripped replace vane. Hope this helps ,Please rate my solution. :)
Jun 25, 2009 | Dryers
Does not spin/tumble
sounds like a broken belt.remove two screws at lint filter .pry top up at front and lid should lift and hinge back.should see belt or mark on center of drum.remove two screws holding front panel from inside cabinet.lift the front panel off two clips on front of unit belt probably laying in bottom.change idler pulley too.hope this helps please rate my solution:)
May 31, 2009 | Dryers
Kenmore Elite Dryer with loose paddle- can I glue?
Unplug the dryer.
Remove the lint filter.
Remove the screws at the lint filter opening.
Pop the lid clips on the left and right front corners of the cabinet.
Rotate the drum counterclockwise until a tumble vane(paddle) is at the 12 o'clock position.
Tighten the screws going through the drum.
Repeat this for the other 2 vanes.
Re-assemble the dryer.
May 10, 2009 | Whirlpool LEB6300 Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
197 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
