Question about Amana ARSE664BS Side by Side Refrigerator
How to use temp. knob in refrig., Amaana
Forgot which way you turn the dial to make it colder....
    President:
  • Amana Master
  • 2,651 Answers
The higher the number the colder the unit will get.
Posted on Dec 21, 2008
Which direction do i turn the temp knob to make it colder? i have no numbers on the unit to go by.
I'm taking a stab at this. But almost every product i have seen, cold is to the left when turning a dial or knob. when it comes to water lines; Hot is almost always left. Hope that helps.Good luck
Jun 21, 2015 | Crystal Cold Propane Refrigerator/Freezer...
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
The ge refrig. is 9 years old. Regardless of the refrig. setting, from 5 down to one it is too cold. set on 3, after 24 hours it is 28 degrees in the crisper and 32 degrees in the main refrig. tried...
ok u ok u turning wrong knob..turn other knob the one with the letters. make the freezer colder than u make ref. warmer. that knob controls a flap that controls how much cold air flows from the freezer to ref. ok
Feb 12, 2011 | GE Refrigerators
Frig is turned down to low and everything is still freezing. Ice maker not making ice.
icemaker not working because to cold in freezer;water transfer tube frozen and will need to be deiced, but first must solve refrig. to cold, making freezer to cold, thermostat problem which is common it is a presure filled and in time can loose presure and will run colder, some have adjustment scew with arrows warmer or colder adust warmer and only turn a 1/4 turn or less until you get in middle of dail range. or replace thermostat. refrig. temp. should be 38 to 40 degrees frenhiet. freezer no colder then 0.
Nov 29, 2009 | Frigidaire GLRS234ZA Side by Side...
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Refrigerator not cooling
you need to locate the defrost timer should be in the same box the temp control is some have little knobs some have funky little screw heads like the screws in bathroom stalls should be a hole in the housing where the thermostat is turn it slowley clockwise till you hear thu unit come on if it before you do that smack the temp control first a couple of times make sure its not sticking then let me know
Feb 16, 2008 | Refrigerators
Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
Nov 23, 2007 | Frigidaire Side by Side Refrigerator 26...
Which way do you turn the temp. knob
loper the number on the thermostat dial, warmer the fridge. higher the number, colder the fridge. normal setting is about "3"
Apr 19, 2007 | Magic Chef MCBR170 Compact Refrigerator
Amana ARSE664BS Side by Side Refrigerator Logo
140 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
