Panasonic plasma TV model TH-42PZ77U. No picture or sound. Power indicator blinks red. What's up?
  • mwcharbo Dec 21, 2008
    The power indicator (LED) flashes a series of 7 short red blinks. One person responded that I should start checking the circuit boards with my multimeter. I need help on a more pedestrian level.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a known common issue with this TV series, with a variety of faults following Murphy's Law. Another hitch is most of the parts are not readily available and are back ordered. Sorry to be bringing you the bad news.
This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional or consider other options.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 21, 2008
  • 505 Answers
7 blinks = scan error
panasonic says:
How to diagnose power LED blinks 7 times symptom.
Possible
Causes:
1. Conduction between the sustain and scan electrodes causes the output ICs to fail on either the
SD or SU board, depending on the location of the damaged pixels. -OR-
2. FET transistors on the SC board fail, preventing the delivery of scan pulses to the panel.
the way it works, the sc (scan) board drives the screen through the su (scan upper) and sd (scan lower) boards. usually it can be any of the three-
If you dont have a multimeter, then you can check it physically.
-remove back panel.
-the 3 boards are on the left side when viewed from the back.
the sc is the big one, and the su and sd will be hooked to the screen with ribbon cables.
-inspect the "snot" ics (chips) on the su and sd boards.
-be very careful! ribbon cables are fragile and break easily. - check all the black chips on the two boards, you may have to flip them over by removing screws (can't remember) .. look at the chips.. even a small pin ***** can be a interal burn up.. check all of them for burn holes or spots.
-if su and sd boards are ok, just replace the sc board.
-if su or sd are burnt up, replace the appropriate board and the sc board.
let me know specifics, i can talk you through it.
    President:
  • 2,110 Answers
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times.
    Master:
  • 505 Answers
First make sure all the cable at the back of the TV is connected properly.
The problem you referred means that the TV is going in protect mode because it detects an internal problem, try leaving it unplugged for a longer time, let say one hour or two.
Basically, what happens is that the TV does not start because it detects that there is an internal problem, such as a wrong voltage, a bad component, overheating etc.
When you unplug power and restart it, you reset the internal circuit, and the TV will restart, not detecting the internal problem.
As soon as the TV gets hot, after staying on for a while, the defective part start giving troubles, as the defective component (probably an IC, starts overheating).
From description, the Digital Processing Board can be cause for the problem as there is no video.
However all the following parts can be involved.
Parts involved can be
LCD Controller
Contact some local tech shop or geeksquad to get the unit repaired.
Thanks
    Master:
  • 479 Answers
Confirm problem for sure in the internal circuit board.it needs to be checked with a multimeter to locate the faulty component on the board.replace it with new component.u can get this components at radioshack or at local tv electronics shop.it could be faulty capacitor or ICs.check it out. thanks.
  • tech gurus Dec 21, 2008
     Six blinks---- No horizontal (H STOP), no raster, goes to the blinking
    self-diagnosis function immediately. Check C515 and 516 and the jungle IC,
    IC206. Seven blinks---- High voltage shutdown. The high voltage has exceeded 33k
    and the unit goes immediately into safety shutdown. Check power supply
    regulation and horizontal circuits. Eight blinks---- Problem with the audio
    (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406
    audio amp, PS401 an
Panasonic model th42pz77u no pic, no sound, blinking red light ten times
9.2. Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
26
TH-42PZ77U:
There are different patterns for blinking light...
10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Panasonic TH-42PZ77U HD Plasma tv has 10 blinking lights
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 02, 2010 | Panasonic TH-42PZ77U TV
Panasonic th-42pz77u has no picture.power light (red) flashes 7 times
seven blinks on this model is the SC board. it will need a new SC board and the software update for the new board. usually only authorized servicers have the software need to do the upgrade. but if you were to contact panasonic then they might be able to have it fixed for you for free since this was a defect in manufacturing. of course this depends on how long you have had the tv.
Dec 24, 2009 | Panasonic TH-42PZ77U TV
TURNS ON THEN OFF, RED LIGHT BLINKS 7X
replace sc board and do firmware update or problem will come back!
Oct 24, 2009 | Panasonic TH-42PZ77U TV
(panasonic TH-42PZ77U plasma) the tv will power on but before the picture comes up it powers back off. Red power light is flashing.
in protective mode the tv does not turn on and light is blinking, typically we must proceed by elimination as some faulty sections are preventing the tv to switch on. unplug the output power connectors from the power supply until the latter stop clicking. if it is still clicking after every of the output rail have been disconnected, then the power supply itself is faulty.
hope this helps!
Mar 21, 2009 | Panasonic TH-42PZ77U TV
Televison & Video Logo
687 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
