Did you have continuity from one brush to the other? Some Bosch tools use "pop off" type of brushes. When they get worn down a spring loaded center pops out and keeps you from damaging the armature. If they are fine check cord continuity. If the cord is fine it is most likely the switch. You can test the field for continuity also but those rarely ever fail. Here is the parts diagram.
Bosch 11264EVS diagram
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
SOURCE: how do you replace the brushes on a Bosch Drill GSB18-2RE
The brushes are usually accessable from the outside, sometimes not, but just remove the plastic cover with a screwdriver, with it unplugged and the brush pops out, replace with one the same size.
SOURCE: The brushes on my Bosch hammer drill have worn
Hi, sorry you have been struggling to find a service centre,this is a link for service centres in the Shropshire area http://www.boschdesign.co.uk/dealer_locator/loc_result.asp?strLocator=&strPostArea=SY&strType=ysn_bsc&intProduct=
Please be aware that if the brushes are badly worn this may indicate a more extensive and more expensive repair
Hope this helps
SOURCE: I have a bosch hammer dirill that won't chip nor drill but motor run fine
Hi, have you tried the various positions on the front part of the gearbox behind the 'chuck'?
If so, then Im afraid it must go in for repair. These are not an easy fix and personally I would recommend you ask for a 'quotation' as it could be just something simple to do with the 'Gearbox' selector, but it could also be something a lot more serious within the Gearbox.
Good Luck & Best Wishes, John..
