Cars & Trucks Logo
Anonymous Posted on Aug 24, 2012
Hot air through floor in 99 Suburban when blower is switched off
When the fan/blower is switched to the off position, the floor vents open, blowing hot air while driving. Is this some kind of 'fresh air vent' that I just need to close? When the blower motor is on, all vent options (floor, panel, defrost, etc.) work properly. However when the blower is switched off, the floor vents open and heat the cabin quite effectively. Tired of sweating!
  • Anonymous Aug 25, 2012
    The heater box door seems to work just fine. The actuator seems to be fully functional when the blower is on. It switches from floor, to panel, to defrost, and everything in between just fine. However when the fan is switched off, the actuator opens the floor vent.
Stephen
Level 3:
Top Expert:
  • Chevrolet Master 21,873 Answers
  • Posted on Aug 25, 2012
 Stephen
Chevrolet Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6199850
Points
67230
I the short answer is yes. The truck has a flow-thru vent feature as does most GM products. When the fan switch is off the outside air would flow into the truck.
I thought you could still direct the air by way of the control panel, but by the wiring diagram it looks like everything is disabled when the fan switch is in the off position.
  • Anonymous Aug 27, 2012
    Short answer to what is yes? Yes I'm stuck with hot air blowing through my vehicle? In that case I have a nice 99 suburban for sale with permanent heat.
  •  Stephen
    Stephen Aug 27, 2012
    Yes it has a fresh air vent that is open when the fan or the main control is in the off position. The air should not be much hotter than outside air, so if it is going thru the heater there is a problem with one of the blend doors.
5 Related Answers
Rick Gillis
  • 37 Answers
  • Posted on Dec 06, 2008
SOURCE: Heat wont blow through heater or defroster vents
The door in the heater box is most likely stuck. It is located under the dash on the passenger side
mikehumble
  • 124 Answers
  • Posted on Dec 13, 2008
SOURCE: heater control 98 chevy s10 blazer
These trucks have a problem where moisture builds up in the heater box then freezes. When this freezes and you change your heater settings it breaks the shaft for the blend door. If this is what happened you should be able to look under the dash above and to the right of the gas pedal and you will see two vaccuum accuators one of them you should be able to wiggle around the linkage if it is broke. To fix this you need to remove the entire dash to get the heater box out which involves discharging the AC and draining the coolant because the heater core and evaporator come out. Please rate.
Anonymous
  • 146 Answers
  • Posted on Jan 05, 2009
SOURCE: 1998 Mustang - AC blows only through Defrost vents
You probably have a vacuum leak on the passenger side. its a small plastic hose some times they come unpluged from the engine. or brake.
Anonymous
  • 20 Answers
  • Posted on Feb 23, 2009
common problem, check under dash by the gas pedal if control arms are muving went selecting from ac to heat cuz this it is the control for the vents to go from ac to heat and to defrost.
Stan R
  • 37 Answers
  • Posted on Mar 13, 2009
SOURCE: PROBLEM WHEN SELECTING THE DIRECTION FOR THE AIR
Sounds like you have a supply vacuum problem. When you lose supply vacuum to the control head it defaults to defrost.
1helpful
Air not blowing out of vent on 1999 chevy suburban
MODE SELECTION IS VACUUM OPERATED. DEFROST AND FLOOR ARE A DEFAULT MODE WHEN SYSTEM FAILS. YOU HAVE A VACUUM LEAK, FAULTY VACUUM SWITCH ON DASH CONTROL UNIT OR A BAD VACUUM MOTOR IN DASH
A/C works fine, the blower's fine, replaced thermostat, no heat.
If you don't hear a thud or noise of a flap opening or closing when switching between hot and cold then a lever is probably broken.
2helpful
2answers
1998 Town Car A/C Blows Hot Air But Is Charged Up
Hi - There may be 2 separate problems. On my 1991 Lincoln Town Car, there is a Thermal Blower Lockout sensor that disables the heater from blowing until the engine temperature reaches a specific temperature. This way if you have vent or floor settings and 90 degrees set and it is winter, you won't get blasted with cold air. When the vehicle warms up, the TBL circuit enables the climate control to blow the hot air. If you use the flr/def instead of the floor or vent control, the TBL should not prevent the heater from working even with a cold engine. On my car, the TBL went bad and always prevented hot air from blowing on the floor and vent settings, even when the engine was hot. Another thing to check is a thermal limitor resistor. It is designed to cut off the blower at very hot temperatures, except if the blower fan is in the hi setting.
As far as the A/C is concerned, can you verify if the clutch is engaging or not? A rapid cycling of the clutch is an indication of low freon. If you are absolutely sure that you are fully charged on freon, I think there are 2 possible causes: (1) Bad pressure switch on the accumulator is indicating low freon that is telling the compressor not to work; (2) a blocked orifice tube.
1helpful
2answers
06 Chevy Suburban Dash fan stopped working
this is because you have a bad switch which has gone bad and you need to replace it or either try to bypass it through another circuit.
Air and heat not blowing air through vents
Either Your fan switch is burned out or you blower motor is no good, your blower motor is on the passenger side under the dash. Before you replace any parts you need to check your fuses and relays under your hood and in the car. Usually if your fan switch goes bad you will still get some air blowing thru the vents, so my guess would be blower motor, If its not a blown fuse or relay.
5helpful
3answers
2004 Ford Expedition XLT, front blend door actuator
Hope I was avle to help, glad you up and going.
1996 GMC Suburban heater blows on floor
yes those controls are vacuum controlle. Could be as simple as a bad hose or connection.
2helpful
2answers
2004 pontiac gran prix gt
I would suggest replacing the blower motor resistor. When this component fails the blower will only work on one spped or none. This is a very common issue with all automotive models
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
