Question about Philips HDR312 30-Hours Video Recorder
Having problems changing channels with philips HDR312
Unfortunately I just got new tv console and pulled all the wires out. all works except that I cannot change channel.
I called tivo and they said I am missing IR cable, some purple cable. can you help describe this?
  • 33 Answers
Hello, The IR cable has a purple color at the end of the connection.
On the back of the Tivo, It should be marked IR.
Looks like a headphone jack type.
Posted on Jul 05, 2010
I have a Philips DVD recorder/player HDR3700. Works fine except when recording comes on the TV channel being watched changes to the channel being recorded which means I have to switch back to the TV...
Its a bug. I have one too and it does the same thing. Try asking Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 01, 2015 | Philips Televison & Video
I have a EWC19T3 tv/vcr/dvd combo my ex-boyfriend threw the remote and shattered it. I have a philips/magnavox universal remote but I've tried all the codes listed for emerson (which is a lot) and none of...
Unfortunately, the remote you picked up may be incompatible with your current TV. (I found older universal remotes didn't work with my newest set that had a digital tuner. These were remotes that worked with ~20 year old tvs (analog only). Similarly a new remote might not work with an older TV. Then you get stuck with the result you have.)
Remotes.com has a substitute remote that has all of the functions of the original remote: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=EWC19T3&uuid=12792355576670
This one will work.
Your TV has Select, volume and channel change buttons on the front of the TV. So a tedious way to deal with the problem is to move to the TV to change channels. The Volume controls are under the DVD tray. Select (toggle TV/VCR, DVD, and external input) is the first one on the left under the VCR cassette slot. The channel up/down is to the right of the Select.
I wish that I could be of more help.
(However, you might try the Philips Remote Code Finder: http://www.urc.philips.com/ and select your country and click on the right arrow. Then find your remote model and see if you can get a single number for your TV. On the newer remotes I looked at, it only returned a code of 0917 for All Emerson devices.)
Jul 14, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Philips Magnavox 2783 c101 - will not auto program tv channels
Ya what you got to do is Grab your tv, and throw it out your window. Garbage tv with built in problems made to be fixed. I had the same tv and i had many problems with it before. Just buy a new one boss.
Feb 17, 2010 | Philips Televison & Video
I have the same problem with my Samsung LE46A656 A1F Full HD
If it was doing it on your old console then its the TV not the PS3.
Causes: HDMI cable (Replace cable), HDMI socket on TV (Get it repaired), If it happens on all HDMI inputs then the video board maybe faulty, Interference - location of PS3 to other equipment.
The first thing to do is move everything else away from your TV except for the PS3, now factory reset the Samsung TV and make sure your firmware is up to date my records show that an update came out in May for your TV, also factory reset the PS3 and setup the HDMI video settings using the wizrad in the PS3, now connect the PS3 through all HDMI inputs to see if its one input or all, if all inputs are the same then the TV maybe faulty.
Let me know how you get on.
Thanks
Sep 05, 2009 | Sony Playstation 3 (PS3) Console
Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
Aug 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My digital comcast remote will do everything except change the channel on my magnavox TV. Volume/power control is fine. How can I fix it?
your tv needs to stay on the same channel for the cable box to work with the tv and you change the channel on the cable box not directly on the tv
Jun 12, 2009 | Philips Magnavox 20MC4304 20 in....
Can not access setup
hit vol down on the tv and hold then with your universal remote puse 1. This will set the tv back to factory defaults and give u acess to all cable channels.
Jan 08, 2008 | Televison & Video
TV antenna problem
Hi peter9,
It is possible channel bad reception is come from the signal of the tv channel not on your antenna. Just forget channel 10.
Best regards,
Philip
Oct 24, 2007 | Televison & Video
Philips HDR312 30-Hours Video Recorder Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
