Question about HP Compaq nx6110 PC Laptop
Won't tune on.
Remove all power & wait 1-3 minutes. Replace either battery or AC adaptor will begin to start & crash in less less then 30 sec. Power led is GREEN when it attempts to start then goes dark.
Any great ideas (ie is it a simple daughter board fix or Motherboard FUBAR)
  • 520 Answers
Remove all power ...lead/battery ...remove all mem ...reseat one mem plug in power lead restart...if same try mem in other slot if same repeat with other mem..if same hd has bad sectors ...I have software to repair this if you want it I'll need email.
you may want to check cpu ...if you can successfully set bios to default it maybe okay...
it wont be vga as no beeps heard and same usually for motherboard.
Posted on Feb 03, 2009
  • HP Master
  • 629 Answers
Sounds like a motherboard problem if a using a different battery and power adapter did not fix it. Though, you may want to reseat the memory modules, or if available, swap them with known-good memory modules just to isolate that the problem is not memory related.
Posted on Feb 02, 2009
Dell latitude 10 st2 e wont boot
Hi voyagerbooks,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30 sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check if the computer gives any series of beeps or if there are any diagnostics LEDs shown on it.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Apr 07, 2015 | Dell Computers & Internet
Hi8 manual
See pic below.
1. Open the DC IN jack cover and connect the supplied AC power adaptor to the DC IN jack with the plug's mark arrow up
2. Connect the power cord to the AC power adaptor.
3. Connect the power cord to a wall outlet.
4. Slide the POWER switch to off. Remaining battery time is indicated by the minutes on the display window. Charging begins.
Apr 25, 2014 | Video Cameras
Toshiba l875d-7332
try doing the hard reset; remove battery and ac adaptor and press the power button for 30 sec; after that reseat the battery and the adaptor and power up the laptop.
let me know if that is working for or not.
Feb 08, 2014 | Toshiba Satellite L875ds7332 Notebook...
Acer Aspire 5610 wont start
Trying doing a Hardreset
Remove the adaptor and Battery and press the Power for about 30 secs
Dec 21, 2013 | Acer Aspire 5610-4648 Notebook
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
My new HP notebook won't turn on. I've had it for one month. There is a light on the side where it is plugged in, but it won't turn on
Unplug the AC adaptor. Remove the battery. Hold down the start button for 1 minute. Replace the battery and plug in the AC adapter. The computer should reboot.
Jan 07, 2010 | HP Pavilion dv6000z Notebook
I have a hp dv2000 thats not turning on the power light comes on
Disconnect the ac adaptor and battery and then press and hold down the power button for 30 sec, and the relese it and connect the ac adaptor and battery and try 2 turn on the NB
Sep 14, 2009 | HP Pavilion dv2000t Notebook
Resetting the "Power On" password
Hi.
Power off laptop. Disconnect mains pack. Remove battery pack. Wait 30 sec. Connect just mains adaptor. Press power on button. press f10 for bios settings. Your passwords are now cleared
Nov 03, 2008 | HP Compaq nx6110 Notebook
Hp compaq 6910p BIOS Bypass
I removed the keyboard, unplugged the bios battery, holded down the power button about 30 secs, plugged back the bios battery, assembled the computer, didn't plug the battery and instead of that just plugged the ac adaptor and the bios passwd was gone =)
Oct 29, 2008 | HP Compaq Business Notebook 6910p - Core 2...
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
HP Compaq nx6110 PC Laptop Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
