My NAD M3 amplifier stops working abruptly.
My M3 stops working abruptly almost every time it’s turned on. The blue light starts blinking in amber and then the amplifier shuts itself off. Sometimes it happens as soon as I turn it on and sometimes after a few hours of normal playback, so I don't think it has nothing to do with temperature.
The owner manual says nothing about it and I have not been able to get an answer from NAD
  • 1 more comment
  • orb8 Dec 30, 2008
    Thank you very much.
    I don't have the amp in a ramp, it is on top of a table with plenty space for ventilation.
    Notwithstanding the M3 is coverd by NAD's warranty, I have not been able to have its dealer change or repair my unit.
    I left several messages in NAD's help center web page but with no real answer yet. I also had serios problems with NAD's M5 cd player, so I am starting to believe that NAD's Master Series lack the quaity one expects from such brand.
  • weirdal May 11, 2010
    Just from the sheer volume of questions on fixya regarding NAD components, they have serious reliability issues as you have found out. I'd suggest calling them and complaining because its harder to ignore a customer on the phone. Good luck.
    For starters, here is the owners manual.
    http://nadelectronics.com/img/manual/NAD...
    Look on page 10. The amber light means it switched to standby. If it had turned red, it would mean it was overheating (which it isn't). The amber light/standby was probably caused by either a bad solder joint or some component that will eventually fail completely and possibly damage other components. Unless you know how to look for bad capacitors and solder joints (just to name a few possible culprits), take it to a NAD dealer and have them fix it.
    Do you have the amp in a rack and does it get warm? An amp that gets too warm to touch will not last long.
    Genius:
  • 1,175 Answers
If NAD doesnt respond , find a decent amp/stereo tech in your area.
I can suggest some depending on where you are.
There's most likely a component failure that regular folks wont be able to fix
Posted on Dec 30, 2008
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
My NAD S300 stopped working,simply could not start, the blue lamp was blinking constantly. I sent it to an authorized service where they told me that the mainboard is a multilayer structure and due to...
Have someone who has experience working with circuit boards take it apart and look at it. They'll probably be able to tell you what parts can be replaced. If it's anything as simple as capacitors and resistors, then you can find the exact parts you need at AllElectronics.com
When they said it was a multilayer structure, that means either there are multiple circuit boards, or it's all surface-mount soldering on both sides of one board. To be on the safe side, assume it's surface mount. It's much more difficult to work on.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 12, 2011 | NAD S300 Amplifier
1721 Inspiron shows flashing amber, three times, then blue.
The cells in the battery are starting to go bad which is why the light is blinking the way it is.
Once you get a new battery put in there the light will stay blue instead of flashing amber.
Jul 04, 2009 | Dell Latitude D600 Notebook
Amp c352 TI 1515456 failure
It sounds like yo shorted the speaker wires together for a short time and smoked the output section of the amp. The amber light is an indication that the amp is in protect mode. If you attempt to power up the amp and still have the amber light even with all speaker wires disconnected, the amp needs repair. The output transistors for that side will need to be replaced.
Dan
Mar 05, 2009 | NAD C352 2-Channel Amplifier
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
Dec 23, 2008 | JVC HD-52G787 52" Projection Television
C355Bee and C162 Problems
Get your money back. I had similar problems with new NAD purchases a year or so back. NAD has had all sorts of repair issues.
I'll never buy anything from them again.
Aug 24, 2008 | NAD C162 Amplifier
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
734 people viewed this question
 Grubhead
Grubhead
