Question about Compaq Presario 5000 PC Desktop
Dead,the cap light does not lite just dead
Switch turns on but nothing hAPPENS just dead
  • cmlbelden Dec 21, 2008
    I have full power at the computer,it does get warm but nothingn going out. even hooked up a different monitor.
    President:
  • 2,692 Answers
No fans , No lights, No sound?  Unplug computer and plug something else into outlet to see if the outlet works. If it does the look where the electric cord plugs into the computer , There is a switch . Make sure the switch says 1, not 0. If that doesn't help either have the power supply checked or substitute another one to see if that may be the problem.
Posted on Dec 21, 2008
  • Thomas F. Schneider Dec 21, 2008
    Replace the power supply , as I said before.
My brake light won't turn off an nothing happens when i push the brake
Adjust the brake lite switch which is located under the dash mounted near the brake pedal arm.
May 25, 2015 | Hyundai Motor 2003 Elantra
My caprice is dead
You could have a failed ignition switch or any part up to and including the starter.
Mar 07, 2014 | 1978 Chevrolet Caprice
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
When I picked up my Kindle to read it today, the screen was on and frozen. I tried to turn the page and nothing happened. I tried turning it on and off and nothing happened. My husband held the power...
Your husband switched the device off. If you give the power switch a short nudge only, it goes in and out of "stand-by" mode, it is not really switched off.
Try to slide and hold the power switch again, until after the power light blinks three times. Should happe after ~5 seconds of holding. The Kindle should restart now --- takes about a minute, but you will see a progress bar to keep you happy during the delay.
Jan 11, 2011 | Amazon Kindle Wireless Reading Device
What could be wrong if my brake lights don't work? I have check the basics and fuses already.All other lights are working but if I press the brakes nothing happens.
First check the brake light switch,to see if current gets to bothsides or through the switch,with the peddle down,so it will direct the current to the brake lites.If it is dead on both sides,check the source to it from the turn signal switch,in the steering column.
Sep 20, 2010 | 1999 Mazda Pickup
Hi, I can't get my Ds Lite to turn on. I plug it ...
you must have loose part into unit or power switch , it needs to be go to the tecnica l store
May 19, 2010 | Nintendo DS Lite Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
1998 Honda Goldwing will not start nothing.
Sort of sounds like a Twilight Zone kind of problem doesn't it. I would have the battery checked for an internal dead short. This is something that happens on odd occasions and can happen even to a new battery. Yea, the little lights will work ( they do not draw much juice ), but the starter motor draws a lot of juice and a shorted battery just ain't got it. Also check the wiring harness connections. One loose connection can cause bunches of trouble.
Mar 14, 2009 | 1989 Honda GL 1500 Gold Wing
Compaq Presario 5000 PC Desktop Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
