Question about Thomson LCDB 03B 27 in. Television
Thomson 28WF64U crt 100Hz. white pixels comes & goes after period
Some times this CRT based 100Hz TV will function correctly all day. The next individual white square pixels appear. Some times in lines, sometimes around the outline of objects or both. This problem can fade to nothing then the picture can get so bad as to be almost unwatchable. The next day be fine again with no problem. This only started recently but is becoming more frequent.
Anybody any idea as to which component may be at fault?
4 Suggested Answers
SOURCE: 32" lcd after a while picture goes to negative (inverted colour) somtimesd on power up also
i allso have a techwood lcd3211. just wondered why you migh think its a wafdale re badged, i am tryng to get mine fixed but no one can get hold of a service manual for this tv. i know they are currys own brand but no one seems to be able to fix them without this manual. currys dont want to know s warrenty has run ou. any information you might know would be appresited. cheers.
Posted on Nov 27, 2006
  • 182 Answers
SOURCE: Thomson 27" LCD TV 27LCDB03B
cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
Posted on Jun 11, 2010
SOURCE: Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Posted on Jul 23, 2010
Screen goes green somtimes thomson 15lcd mo3b
HI. If it is not a problem with the CRT itself, look for bad solderings on the CRT socket. If it is in the CRT, you have very bright green with white stripes across.
Oct 05, 2014 | Televison & Video
My Thomson TV 28WF401G is about 7 years old and has now started to automatically switch itself off after only a few minutes of being on. The red 'off' LED flashes several times, stops, flashes...
U have tools like a soldering Iron and roll of solders?Can u also do basic soldering works?Yes take the tv aparts and resolders the FBT-(flyback transformer) that the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).Also the tv video board that the board that hook up to the tv CRT-(tv tube) tube neck hook on to this video board.Resolders that board too.70-80% will get the tv working again.
Aug 19, 2011 | Thomson 28VK25US TV
I have a 10yr old thomson TV 21"some sort of unusual voice is coming out what to do??
I have an old Thomson TV 21FDR more than 10 years old. Recently the Tv screen has a lot of disturbances with the screen full of hirizontal lines and a hissing sound. A well trained technican had replaced the tuner with a new one . But after some 2-3 days the same problem is with the tv. Kindly help me with suggestions.
Aug 22, 2010 | Thomson 21DC320 21" TV
28VK25US Thomson tv, install menu comes up each time switched on.
My Thompson TV only works on av3 thus I cannot get discs to
accept as this has to be on av1 how do I tune in?
Jan 28, 2010 | Thomson 28VK25US TV
We have thomson tv 32" color crt sort length model 29df45 c s /icc20
tv power goes off when vcd / dish receiver is connected
Aug 12, 2008 | Thomson 29DM400 29" TV
Reddish screen on sony wega kv-28fx68 100hz trinitron
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting.
Oct 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Retuning having moved to a new area
blue screen is due to problem in blue video circuit. please check 1 supply to blue video ckt. 2 crt base loose. 3 components in blue video ckt. 4 loose contact in blue cathode ckt in crt base. 5 blue video transistor. 6 signal coming to blue video from signal processor. 7 signal processor ic. good luck.
Sep 29, 2007 | Thomson 14MG135 14" TV
Flashing in and out picture
This is crt base failure due to corrosion. That is why to wont get clear picture initially when you switched on in long interval period. Change crt base problem solved.
Sep 09, 2007 | Toshiba 27AF41 27" TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Thomson LCDB 03B 27 in. Television Logo
134 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
