Question about Onkyo TX-SR606 Receiver
Onkyo TX-SR606 bass treble settings seem to make no difference
Have tried multiple ways to set up new system, but it seems to make no difference in sound when I set the bass and treble settings to different levels. Using only 2 ceiling speakers, and Audyssey does not work either.
I ran into the same issue and was stumped at first. Then I noticed somehow I had changed the sound processing to "Direct" which meant the signal coming from the source was bypassing all of the control in the receiver. All I had to do is select another option (press stereo for example on the remote) and kick it out of the direct mode.
Posted on Jan 09, 2009
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
I cannot get video signal from my Samsung p1590 Blu Ray player via HDMI to pass through my Onkyo TX-SR606 AV Receiver. I get video if I connect Blu Ray player directly to TV, and have tried all HDMI ports...
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Onkyo TX-SR606 Receiver
Unsure of audio setting using Onkyo TX-SR606 connected to PS3
The PS3 should default to the DOLBY DIGITAL sound output so your ONKYO should be setup to the Digital input, TV logic is a matrix similated multi-channel and I doubt if any PS software is in the DTS audio format, look at your game software disc`s and they will inform you of the audio capabilities.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Can someone tell me what the audio setting on the Onkyo TX-SR606 should be when the PS3 passes the signal as full multi-channel. My receiver always seems to say something different i.e. Dolby Digital or TV...
If you're running an optical cable from the PS3 to the receiver, best quality would be through the Dolby Digital, because that broadcasts in 7.1 HD Audio Format. There should be a way to get a default setting when the optical input is detected in your receiver.
Clicking noise from Onkyo TX-SR606 during television broadcast
I seem to recall a sub-menu setting having to do with "auto shut off" or something like that.
My receiver is packed up, ready to take to Fry's, or I would find that submenu for you.
Jan 04, 2009 | Onkyo TX-SR606 Receiver
No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Dec 16, 2008 | Onkyo TX-SR606 Receiver
I have an onkyo tx-sr606 with speakers set up at 5-1 channel, when trying to set up the auto speaker set up i keep getting the speaker detect error message. what can i do ?
hi there. try to check if your surround speakers are on the surround terminal. do not put them on the surround back terminal because this is only allotted for the 7.1 speakers. hope this helps.. ^_^
Aug 12, 2008 | Onkyo TX-SR606 Receiver
Low treble
I suspect that the speaker levels need to be set. You connected everything right - many people would not have connected the sats via the bass section (which has their high pass crossover and overload protection). But I am betting the HSU is turned up a bit on the high side.
Try this. Set all speakers to small, set all levels to 0. Play the receiver in stereo all mode. If the bass is strong, you need to turn the HSU down closer to a natural sound. Then use the speaker setup tone and adjust as needed.
May 14, 2008 | Onkyo TX-SR304 Receiver
Treble and bass function
In looking through the service manual for this model, I see a Tone Switch that allows you to bypass the tone circuits, and it may be the one all the way to the left of your front panel. If that's not it, I would get out the owners manual and see what they suggest. I doubt that you actually have an electronic malfunction with your unit.
Jan 18, 2007 | Onkyo TX-SR503 Receiver
Onkyo TX-SR606 Receiver Logo
486 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
