Question about Tools & Hardware - Others
Is there set up blocks for cabinet door set 97-108?
I purchased the set and would like to know if there is set up blocks that I could buy. The set is a Christmas present from my wife and I haven't opened the package. The instructions may answer my question but I would like to order the blocks now if possible. Thankyou.
  • 285 Answers
Usually set up blocks come with tghe specific router bit cutters. Or, just get some scrap stock the same width that you plan on using for the doors and make your own set up blocks to suit (doesn't take long!)
Posted on Mar 01, 2009
Curb weight 1986 29 foot southwind motorhome
The weight is about 17000 lbs.
The weight is posted somewhere in the RV. Could be on a visor, inside a closet or cabinet door, or on a door panel.
Oct 09, 2016 | RVs
We have a Horn Sewing Machine Cabinet and two of the door hinges have broken. ( Horn 270 Hinges ) Do you know where we can buy replacement hinges ?
quality hardware shops have small hinges
cabinet makers have addresses of cabinet hard ware supplies
or on our horn cabinet there are 2 long hinges ( piano hinges from a hardware shop) that go the full length of the doors
Sep 11, 2016 | Ovens
What are the benefits of buying secondhand fireproof cabinets?
Second hand fireproof cabinets to protect valuables like files, documents, cash, jewellery and more.It will give us the liberty to make a cost effective purchase that is up to our satisfaction the convenience it offers for you to bargain on your purchase and settle down for a good amount that is reasonable to u...For buying best quality second hand fire proof cabinets
Visit us at:
Fire Cabinets Direct
U32 Haddington Sq
Haddinton Rd, Donnybrook, Dublin-4
1850 220880
Dec 26, 2015 | Home Security
Can I buy a new door for my dishwasher?
Refer this inquiry to the purchase source
Oct 20, 2015 | Stainless Dishwashers
Freezer not Freezing and Refrigerator not cold enough
Good Afternoon Brian - Being that you have a top mount, the vent in the freezer is what circulates air down to the Fresh Food section, making it cool. Also keep in mind that if the garage is above 110 degrees, your refrigerator will have difficulties performing optimally due to un-circulating air. You can purchase the garage kit by going to the manufacturer website and clicking on "Filters and Accessories". Alternatively, you may be able to purchase this kit from the dealer where you purchased your appliance. Here are a few simple troubleshooting tips that may help you resolve this issue:
1. First check clearances around your refrigerator. There must be adequate space around a refrigerator with a static condenser so that air can circulate properly. Proper clearances include 1" at the back and 3" on top of the refrigerator.
2. Examine your doors. If the doors have been opened too often or for too long, this may have allowed warm air to enter the refrigerator. Make sure to shut the door completely and be sure not to keep the door open for too long. Even leaving a door slightly open can allow too much warm air intake. Make sure refrigerator is level and keep food and containers from blocking the door closing.
3. Check the door seal. You do this by placing a dollar bill between the body of the refrigerator or freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet, double check to see if the door is being blocked by anything that may be stopping it from closing. If nothing is stopping the door from closing then replace the gasket. (Most appliance owners can easily do this without any tools or sealant.)
4. Check to see if the condenser is dirty. A dirty condenser cannot release heat efficiently into the surrounding air. Cleaning the condenser may be necessary, more if you have animals in the house. If you have condenser coils, they should be wiped occasionally with a damp cloth to remove accumulated dust. The condenser coils should be wiped occasionally with a damp cloth to remove accumulated dust.
5. Check for any obstructions to the vent to ensure proper air flow. If the vent is blocked, the air in the refrigerator will not get cool.
6. Double check the freezer control. If the freezer control is set too warm, set freezer control to a colder setting and allow 24 hours for temperature to stabilize.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Jul 15, 2013 | Frigidaire FRT17B3A Top Freezer...
I have a bathroom cabinet door that came off and now I can't get the screws to stay in as the inside of the cabinet is so damaged and wood filler does not work , even glue will not hold this door back on...
Buy a dowel pin the size of the hole in the cabnet then use carpenters glue to glue the dowel pin in place where the old hole was make sure it is a good tight fit. Next saw off the dowel pin and let set over night then drill a strating hole in the dowel pin and reinstall the door works like a chanp. Hope this helps.
Sep 28, 2009 | Duravit 6130 Starck 1.2.3 Vanity Unit w/ 2...
Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
Tools & Hardware - Others Logo
133 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
