Question about Linksys Computers & Internet
Unable to connect to the internet
Using a linksys wireless-n router, pulling a 169 ip address, showing a decent wireless signal and under the linksys wireless setup it is showing a good signal..
but still unable to connect to the internet
isp is hughes net
  • 51 Answers
Open your web browser. Type in 192.168.1.1 into the address bar A dialogue box will pop up. Leave the username field blank and the password is admin. Once the webpage is displayed, scroll down until you find Local IP Address. Change this to 192.168.2.1. Scroll down and click save settings. Now attempt to access the intnernet.
Posted on Dec 24, 2008
I have a LinkSys WRT54G2, Vers 1.0 router with the latest firmware installed and basically default configuration. I usually have 3-4 PCs connected to the router. I frequently loose connection to the...
Sometimes, you might face a situation where your wireless icon shows that you are connected to the Internet but you just can't access any websites. What do you do when you face this problem?
This article will show you how you can repair Internet connection when wireless icon shows connected, but unable to go online.
To connect to your wireless network with Wireless Zero Configuration, please click here.
In checking if you're computer is properly connected to the Linksys Router, you will need to perform four steps:
i. Checking the Physical Connection to the Router
ii. Checking the LEDs
iii. Checking the IP Address of the PC
iv. Pinging the Router
NOTE: To check the computer's connection to the router using Mac, click here. If you are using Windows Vista, click here. For Windows 7 users, learn more here. For Windows 7 users, learn more here.
Make sure that the computer is connected to one of the four Ethernet ports of the router and the modem should be connected to the Internet port. For more instructions, click here.
Checking the LEDs
The Linksys router's LED lights will indicate the status of the connection. After connecting the broadband modem and the computer to the router, make sure that the LED lights are lit up. For more instructions, click here.
The IP address of the computer is another indication that the computer is properly connected to the router. For instructions, click here.
Pinging the Router
Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is "192.168.1.1."
Dec 06, 2010 | Linksys WRT54G2 Wireless Router
No internet with wireless laptop
may i know whats your router model and also your laptop, the OS that has been installed also there.. and add more info regards to your problem.
thanks
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Secondary computer will not connect wirelessly; IP address problems.
If the router is not assigning an IP then you are probably not actually connecting to the network. Try disabling your wireless security on the router and see if they connect. If they do then you know the problem lies in that direction.
May 31, 2009 | Linksys WRT350N Wireless Router
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless connected to router, signal fine, no web pages
First thing i would try is power cycling your equipment. Unplug the router and the Modem-
Plug the modem in first and once all the lights come on- plug in your router- then restart your computer.
Apr 09, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G wireless connection problems.
click on Start -> Control Panel -> Network Connections -> Wireless Network Connections -> Properties -> In the box in the middle scroll to and click on "Internet Protocol (TCP/IP)" -> Click Properties -> Make sure "Obtain an IP Address Automaticaly" is Ticked -> make sure "obtain dns address automatically" is Ticked. -> ok -> click ok
See if you can connect
Click on Start -> Run -> Type CMD and hit enter.
a command box will open. type in IPCONFIG/ALL
Please copy down the following numbers ---
IP Address
Subnet Mask
Default Gateway
DNS Servers
Please make sure you copy them correctly and post them here.
Dec 24, 2008 | Linksys Wireless-G Broadband Router
Wireless shows connection,but will not connect.
This kind of problem occur due to dhcp disable in the wireless router for the security purpose. So try to give the ip adress manually by right clicking on the wireless and give the ip adress of the same range in which your network in working e.g 192.168.1.0 is the range of your ip addresses so please select the ip which is not been used by any other computer and than in default gateway enter the ip address of you wireless router and you will be able to access the internet on your system.
Dec 01, 2008 | Linksys Wireless-G WRT54GS Router...
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Wii connection issues.
You can check if the problem is with the internet connection going to the Wii or just the wireless connection.
When you loose connection, check the Wii's ip address. If it does not have an ip address(or ip is 169.xx.xx.xx) that means that the Wii is disconnecting from the wireless network. You can then try other wireless channels on your router.
If the Wii is still getting an ip of 192.168.x.x, that means that the problem is the internet from the router. You might need to forward ports on the router for your Wii.
Mar 13, 2008 | Linksys Wireless-G WRT54GS Router...
Ip Address 169.x.x.x Wireless Internet Connection Problems 6400/E1505 Dell Laptop
when you renewed the ip address, windows assigns an ip address of 169.xxx.x.x, this your router will not be able to see. if you have enabled dhcp in the router, check that the wireless card is set to obtain an ip address automatically. If you have no luck that way, go to another pc and in the network card properties, look at the assigned ip address number that the router has given the pc, eg 192.168.2.2, if you have more than two pc you can bet that the other number assign wil be 192.168.2.3, so go to the problem pc's network card problem and and set the ip address manually to eg 192.168.2.4 and set the dns address to 255.255.255.0, save settings and try connecting again. the only other thing stopping a conection would be if the security, eg wep or wpa is enabled and the number has not been entered correctly into the network card properties.
Jul 26, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
175 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
