Question about Car Audio & Video
My amps not working anymore.
When hooked up the lights flicker and no sound comes out. how could this be fixed?
  • 21 Answers
First check your ground wire then you power wire connections .. check the fuse to see if its making connections on both ends of the wires..
i think the flickering is the result of a weak or bad connection in the power ground or acc wire "normaly blue"
your amp has no sound because the amp has to charge before it can out put at a higher amperage
hope this helps
Posted on Dec 21, 2008
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Jul 21, 2009 | Kicker ZX10001 Car Audio Amplifier
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
No sounds coming out of subwoofers
CHECK INSIDE UR SUBWOOFER BOX ...
Apr 11, 2009 | Pyle PLAM2300 Car Amp
My sub flickers on and off in my truck!!!
could be a number of things loose wires bad ground fuse on its way out or internal problems
Feb 13, 2009 | Profile BAJA HA700M Car Audio Amplifier
Audiobahn amp help...
You have a Direct Short in the System Between the Head Unit and the Amp. Check the Ground on the Amp and then Check all the Wires behind the Stereo and the Common Ground There. You could even have a Spot in the New RCA Cables that is Touching Metal Somewhere. Please Rate My Response! Thanks!
Feb 09, 2009 | AudioBahn A2002T Car Audio Amplifier
Protect light
Does the amplifier do this when you don't have the sub hooked to it? If so, you have a pinch/short in your ground or power wire. If not, the subwoofer has a short in its voice coil or the amplifier needs to be repaired as it cannot handle a typical load.
Dec 29, 2008 | MA Audio HK401SX Car Audio Amplifier
1507 v12 amp
Are you installing the correct fusing inline near the battery and are you sure that you're hooking the amp up properly? Sounds to me like something isn't being wired properly.
Jun 24, 2008 | Car Audio & Video
Rockford Fosgate P3002 Amp
what are the color of the lights that stay on.red= protect/ green=on.if the amp has little sound it probably still working,check deck output volume(rca)
Aug 22, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
130 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
