Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Replaced lamp, now no fan & hot plistic smell, (of course)
Ok, replaced the lamp using an osram replacement into the orignal housing. habe done this previously, this time the fan doesn't come on & smellslike ver hot plastic. Thoughts?
  • rjferry Dec 21, 2008
    re: the processor monitors fans, nice little bit of info...
    This is the third lamp for this set, I always use bare bulb replacement into the original housing, although I admit it feels like it's getting a bit brittle from the heat.
    Nothing different this time around.
    When the lamp failed the fans did run, now there is no fan noise, nor air flow, although the pix is back.
    I'll pull the bits and check again.
  • 41 Answers
This model monitors the fans, should one not work the set should not even turn the lamp on, leaving only the timer LED flashing. Recheck your work but you have had other problems to begin with. Be sure the covers are reinstalled properly. Are you getting a Temp LED that is lighting? If so then the Temp sensor needs to be replaced.
Posted on Dec 21, 2008
Replacement bulb/lamp availability
Google search your manufacturer make and model and the words replacement lamp. You can find reputable vendors it in the search results.
Mar 31, 2015 | Televison & Video
How to remove headlights to replace bulb on twin hella.
Most German type Hella lamps are removed from inside the hood/bonnet with a quarter turn twist, and then pull straight out, remove the wiring connector first and see which way it gives when turning gently. Replace your lamp with the proper replacement from OSRAM. They make more improved versions than the OEM includes with your car. Hella uses OSRAM/Sylvania (USA) bulbs as std.
Mar 21, 2015 | Cars & Trucks
Premature Lamp Blow
Have you been turning off this set from some OTHER power source, such as a cable box ? The set MUST have constant power for at least 3 minutes after turn off for the bulb to cool down. Also, do NOT use a generic "bargain bulb" to replace--either an original or a phillips one do NOT use an Osram "neolux" lamp, Mits. do NOT like them !!
Apr 11, 2014 | Mitsubishi WD Televison & Video
Dust has accumulated inside the optical assy and cooling fans espesialy on the lamp cooling fan.
Mar 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Hi, your part # will be 915p020010. The original maker is Osram which last around 4000 hrs. You can get the Philips which last 6000-8000 hrs with a superior picture quality,only if you have the housing that has a white cart board covering the back of the lamp.If your housing is complete plastic you will have to get the original Osram. Here's the link where I found it:
Jan 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Replacement lamp not bright
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Mar 05, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi wd 52725 lamp troubles
You can use Mitsubishi 915p020010 or Osram E023. Remove the front and clean the lense using only a clean microfiber cloth. dirty lense main cause of dark picture. The lamp could be incorrect wattage.
Mar 05, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Burning out lamps on my 65inch dlp
I have 65" Mits. lamp lasted about 2+ years and burned out. bought new on internet, that lasted about 5 months and went. Got free replacement and that lasted about 4 months. No more free replacements ...
Bought new from different source and it burned out in a week.
Note: These were ALL OSRAM original lamps from reputable suppliers.
They sent a new one but also cautioned about cleaning the "filter" on the lamp housing. NOT the large screens on either side, but the small rectangular one (about 3/4" x 2"). I did this with a shop vac pulling and pushing from every angle and it was really clogged almost solid. No way air was going across the bulb to cool it.
THIS IS CRUCIAL and I feel is the keys to the kingdom! I did this and voila - no more "plastic smell" when installing the new lamp and everything's great!
I feel that Mits should be held accountable for this for not recommending the lamp housing be cleaned periodically (maybe yearly). I really feel if this were done with my original one it would have last a lot longer.
Dec 14, 2008 | Mitsubishi Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
