Question about Mitsubishi VS-60609 60" Rear Projection Television
Mitsu. 60-inch VS-60609 Green Light goes out..tv goes off.
Power the tv on and green light either flickers or goes out completely. If it goes out completely, the tv will turn off automatically. I pulled the chassis out today and noticed if I applied inward pressure on the top right side of the a/v input/output board..the problem would not surface. I not sure if thats the official name of that or not..Its the board you would plug/screw the cable cord or audio cords into. I notice it connects at the bottom..but unsure of the necessary steps to correct this. Any help will be greatly appreciated.
I have pics but see no way of posting them on here.
  • ThePanga Jan 03, 2009
    My Mitsubishi VS-60719 turns on, but turns off in 15 seconds or so.
  • tammynjimmy Mar 14, 2009
    when i plug my t v up the green light flicks on then goes off causing the t v not to come on
  • 41 Answers
You are dealing with bad solder connections. The solution is to pull the board, put it under a magnifying glass and resolder all suspicious connections. before going too far with pulling the chassis, look over all the boards near the egde under the tubes. Be sure there is no liquid present, if there is give it up the set is toast. If not then continue on and place piece of plastic draped over the front of the left and middle boards to about 5 inches in towards the center just before putting the back on the set.
Posted on Dec 21, 2008
My tv will not turn on
Does the set if model listed here is correct come on with the green power light for a few seconds and then that goes off?
Dec 22, 2012 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi vs-60609 will not power on when it is pluged in the green light flashes three times. The manual says this means the microprocessor is functional. I ran the self diagnostic (as suggested in the...
Unplug,replug it an hour later tv now,resetting back to factory setting.Should work now,not than the DM power supply board is dead.Try website like Tvrepairwold.com to buy a capacitors kit to replaced those dead capacitors on the DM power supply board.
Sep 09, 2010 | Mitsubishi VS-60609 60" Rear Projection...
Left convergence on mitsu vs-60609
Convergence IC's inside of your TV are nearing end of the life. If during adjustments that you made Red and Blue was moving in all directions (left, right, down, up) than resistors and fuses still probably OK. IC's (part number will start with "STK" and they attached to huge aluminum radiators) have to be replaced and fresh heat sink compound have to be applied.
After that convergence adjustments should not be a problem. And color will stay together for another several years.
regards.
Russ.
Apr 04, 2010 | Mitsubishi VS-60609 60" Rear Projection...
No picture, no sound, green light flicker ongoing
The power supply in the Tv has failed and should be looked at by a qualified technician.
Sep 09, 2009 | Samsung Televison & Video
Green light flashing
This is most commonly caused by the Formatter not booting up. The cure is to replace 4 capacitors on the Formatter board 1000 mfd @ 16vdc. The Formatter is the large stand up shielded board on the left as you look in from the back of the set. The capacitors will be domed on top if bad.
Dec 11, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-60609 60-Inch (Green Light Flicker)
Check the VU connector between the deflection and signal boards on the foil side for ring cracked connections... Pin 13 is blue and I think 12 is green... If cracked simply reflow some solder on each pin and re-assemble.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 13, 2008 | Televison & Video
Mitsubishi VS-60603 60 inch Projection TV
You would have to completely take the Mirror out or Mylar backing and being careful not to damage anything, trying to move and reassemble when you get at the new location.
Dec 05, 2007 | Mitsubishi VS-60609 60" Rear Projection...
My screen is turning colors
May it have been knocked about so the projectors are out of alignment, or may it have been standing next to a powerfull magnetic field?
It may also sound like a mirror may have become misaligned, since the top half is affected
Nov 07, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS 60609 60 inch
Hi, I need a Diagram for a Mitsubishi VS-60609 my E-mail: varo9@hotmail.com Thanks!!!
Oct 16, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-60609 60" Rear Projection Television Logo
534 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
