Question about Sony KV-32XBR450 32" TV
I have a white Verticle line but I get a picture
I have a white vertical line on my screen. I have a picture but white line is there in the middle of the screen. I have satellite service and they suggested getting new cable wires, any suggestions before I buy this stuff?
I can see movies such as dvd's and VHS tapes on the TV without the line, line is there only when the satellite service is on.
  • theresa5929 Dec 21, 2008
    Thank you, saved me from buying new cable wire....T
Have you tried unplugging the sat receiver and plugging it back in? This will reset it.
Posted on Dec 21, 2008
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
The tv has a 3" white verticle white line down the middle
Sounds like your LCD panel is failinf and will need to be replaced it is going to be costly around 1500
Nov 29, 2009 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
I have laptop dell inspiron 9300 it 17 sreen , it has a white verticle white line about on the middle about inche 1 1/8 wide hohow to fix? thank you...very much
Unfortunately, there is no way to fix it.
This line called "Tab Separation" of LCD.
You'll need whole new LCD display.
Very very common problem.
Apr 29, 2009 | HP Pavilion zd8000 Notebook
No Picture On Screen
change the 33uf 35v at the vertical filter
Thans!
Mar 10, 2009 | Televison & Video
Verticle hold transistor?
The vertical hold keeps a normal picture from rolling either up or down. You don't have a normal picture (raster) here.
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace.
Good Luck!
- Jim
Jan 24, 2008 | Televison & Video
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
DS25390 Verticle foldover
If you have a picture but the top is folded over, your vertical IC is probably good and you need to replace the pump-up capacitor next to the IC. When the pump-up cap (typically a 47 or 100uF 35V cap) is open then the picture will have white lines and foldover at the top. The typical vertical output IC is the LA7838, but I am not familiar with exactly which output IC your set uses.
Jul 02, 2007 | Sanyo DS25390 TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Sony KV-32XBR450 32" TV Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
