Question about Maytag Dryers
Dryer was running and sparks flew out the back
It got really hot and smelled like something burning before it had sparks and quit
    President:
  • Maytag Master
  • 1,922 Answers
Probably the heating element had a hot spot in the coil of the element and it either sagged from heat and touched the case of the dryer and arced which threw sparks or it just separated with the same results
Posted on Aug 27, 2012
SOURCE:
  • 1028 Answers
SOURCE: smells like somethings burning, more
ckd exhaust vent for restriction
Posted on Jul 30, 2008
did the drum stop turning,when motors overheat they smell realy bad.
Posted on Nov 01, 2008
  • 4 Answers
SOURCE: dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Posted on Feb 24, 2009
  • 108 Answers
SOURCE: Dryer was running with full load of clothes.
Well it sounds like a sound I have heard... forgetting that I had a cigarette lighter in my pocket and having it explode from the heat in the dryer. But you say you heard two loud pops?
Once everything cools down, check again and report back... does the dryer not turn on at all? Does the light come on when you open the door? Does it buzz when you push the start button? Stuff like that.
Posted on Jul 27, 2009
SOURCE: Dryer got very hot and smelled burning..
This is usually a result of a stalling idler pulley or drum, causing a burned spot on the drum drive belt.
The situation will only worsen. The belt is best replaced before it breaks.
Items to pay attention to, when the drum drive belt is replaced, are:
(1) Clean and lube the idler pulley and drum roller shafts.
(2) Confirm that the drum glides will yield additional service life.
(3) Check motor condition and de-lint the blower housing and blower intake pathways.
Posted on Sep 08, 2009
Blue sparks and burning smell while hair dryer is on
After 4 years of service it can be expected that your hair dryer will be needing replacement soon.
Jan 10, 2014 | Revlon 1875W Hair Dryer RV473
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
When it runs, it runs too hot even on low and burning smell
needs new thermostat DO NOT USE IT IS A FIRE WAITING TO HAPPEN
Sep 18, 2009 | Kenmore 62602 Electric Dryer
Dryer quit getting hot
I would suggest that your thermostats/cut-outs have gone as a result of overheating .. Also replace the door switch as this is a safety device to stop the drum from rotating whilst the door is open
Aug 25, 2009 | Kenmore Dryers
Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Aug 12, 2009 | Kenmore 63942 Dryer
Dryer stoped running
Feb 24, 2009 | Maytag Dryers
Hot electrical smell
take the back panel off and look for the melted peice. then you got it.
Jan 26, 2009 | Frigidaire GLER341A Electric Dryer
My dryer in my stackable washer/dryer quit
I Think the belt got binded on the motor spindle and the burning smell was the belt burned through by the spinning spindle
Mar 23, 2008 | Dryers
Dryers Logo
193 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
