Question about Remington NEDH-2500 Nasal/Ear Trimmer
Trimmer Broke I tried to replace the battery. The cheap plastic cap broke off when unscrewing it. The trimmer won't work without it. I just got it a couple months ago. Of course I don't have the receipt. Can I get Remington to replace the trimmer? Who should I contact?
  • 944 Answers
Call this number; 1-800-736-4648 Or go to this link; http://www.remington-products.com/consumer/contact.htm Hope this helps :)
Posted on Apr 04, 2007
  • Planetoid20 Nov 30, 2010
    The link shown above http://www.remingtonproducts.com/consume... leads to a "File or directory not found" message only.
  • Planetoid20 Jan 06, 2011
    On 1/5/2011 I called the telephone number shown above (1-800-736-4648) and reached an unidentified person with Remington's electric shaver products department. He said that Remington nose and ear hair trimmers are not repairable. He also said that he had no information about how to disassemble a Remington ear and nose hair trimmer.
Pull cord broke, broke it down, can't get to it??
You will have to take the trimmer apart go to Parts tree Repair Clinic they will have a video
Jul 12, 2014 | Craftsman WeedWacker Gas Trimmer 29cc...
Gh700 grasshog trimmer - round plastic gear drive broke in half - can I get a replacement or even a metal gear?
Same problem; GH700 with a stripped gear, inside the casing.
I wish places with replacement parts sell uncommonly broken pieces... I didn't have an account for commenting a request in that site.
If someone asked them, it could be available in a matter of time.
Black and Decker GH700 14 GrassHog Trimmer Edger Parts
Sep 01, 2011 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
McCulloch 2500CXL - When I tried to change the trimmer head according to the instructions in the handbook page 8 the casting broke away where the screwdriver was inserted when I tried to unscrew the...
The casing that broke away must be of the cheap "pot metal" variety. That is unfortunate. See if you can soak the area where the head is screwed onto the end of the shaft with penetrating oil like PB Blaster or Liquid Wrench by turning it upside down. If you can, let it soak overnight. A strap wrench would be handy to hold the casing possibly or maybe put a rag around it and hold it with a large tool (pipe wrench) or large vise. If vise grips fit on it, you could try them with a rag on the casing for protection. Post back as we would like to help.
Oct 20, 2010 | Husqvarna Garden
I have a ryobi hedge trimmer p2601 and the plastic handle broke. Is there a way to get a stronger handle or just a replacement?
May 29, 2010 | Ryobi 18V Hedge Trimmer
I need to put in new string -- don't know how to install. I need to know what to remove -- do I unscrew something, or do I just stick the string inside the casing?
This trimmer is an "AFS" (Automatic Feed System) trimmer meaning the trimmer uses centrifugal force and a lever that play out trimmer line without you ahving to bump it on the ground. Your trimmer uses .080" diamter line. You can get a replacement spool and lever at Lowe's fairly cheap. I would say get the spool that is already wound rather than trying to buy just the line and re-spooling...that will make this a LOT easier!
What you do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head of the trimmer and follow the steps below:
1. Remove the spool cover (this is the orange cap on the head)
2. Remove the spool, (observe and note the orientation of the spool!)
3. Using a pair of pliers, pull the orange feed lever straight out (observe and note the orientation of the lever!)...do not try to pry it off, you will damage the head!
4. Insert the new lever in the same orientation you noted when you removed the old one.
5. Insert the new spool and line in the same orientation as the old spool.
6. Replace the cap.
Black and Decker has an 800 number you can call if you get stuck, the number is 1-800-544-6986. Good Luck!
Nov 04, 2009 | Black & Decker 14" Grass Hog Xp...
Starter cord on Ryobi PLT3043A broke - is it simple to replace?
unless you are mechanically minded you can run into trouble it is best to get a quote from your local dealer
Jul 03, 2009 | Ryobi 15" Electric Factory Reconditioned...
Case won't opem
There is a screw underneath the Toro label.   I learned the hard way.
Jun 09, 2009 | Toro& Electric String Trimmer
Broken pull cord
You have to take four allen screw out of the plastic that holds the engine on. There is also one by the spark plug that needs to come out. Once the engine is loose, you have to unplug one wire and unscrew the other. Then the engine should come off. Then loosen the two allen screws holding the pulley in and it will come out.
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Weedwacker wont turn off
We have a Black and Decker CST 1000 and other than the convenience of no cord, it constantly has problems. Won't hold a charge, spool holder cap broke and we can't find the part, handle cracked and finally broke. We have a black and decker blower and it won't turn off either. Fortunately it's corded so we can just unplug it. No more Black and Decker for us.
Jun 05, 2007 | Black & Decker String Trimmer Cordless 12"...
Trimmer malfunction
I had same problem, at first I could not find out how to seperate the small silver cover with the on/off switch from the rest. After removing the 3 torx screws, 1 at the power entrance, and 2 under the shaver blade. You can remove the black cover. I also removed 2 more torx screws to separate the battery, from the rest, (don't know if thats really necessary). The silver covers are 'clicked' into eachother. When lifted the part where the battery part was screwed into, the silver parts became partly seperated, then you can pull the part apart.
I cleaned/washed the trimmer part with wd40 contact spray.
Assembled the parts, and made sure that the little plastic nodge was came into the trimmer.
Cleaned it all (removed leaking wd 40) and works fine again.
Hopefully this is helpfull to anyone.
Goodluck,
Adrian
Dec 25, 2006 | Braun Cruzer 3 Electric Shaver
Remington NEDH-2500 Nasal/Ear Trimmer Logo
120 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
