Question about Black & Decker B2300 Bread Machine
One paddle does not rotate element heating only on one end
One paddle does not rotate when there is resistance on it ex.flour mixture when a loaf was to be prepared only half cooked it seems that the element is only half working
  • 1 more comment
  • Anonymous Jan 03, 2009
    Though we have cleaned the machine very thoroughly and the paddles work and move when the bowl is empty, once the flour mixture is in the machine, only one paddle is working and there is a constant clicking noise. Obviously, the loaf is not balanced and we lose some of each loaf. Is there a solution to the problem or do we call Black and Decker for replacement parts? Help!
  • Anonymous Jan 04, 2009
    Same problem - one paddle does not rotate as soon as there's any amount of resistance. It's the left one.
  • MJB52 Jan 18, 2009
    I also have the identical problem. The paddle on the right does not turn the moment the dough touches it. As soon as the dough is clear of the paddle it starts to rotate again. I contacted Black & Decker about this issue just before I checked this site. This is a nice machine otherwise.
I have the same problem and it seems to be the plastic gear on the bottome of the breadmaker have tried gorilla glue and hot glue still brakes under pressure am going to try to screw the metal plate to the gear on either side of the shaft will post my results
Posted on Nov 22, 2009
  • 368 Answers
Hi Tim,
I think this is a (hopefully warranty) repair issue
http://www.blackanddeckerappliances.com/customercare/contact-us.jsp
Get ahold of B&D, and let them handle this. There are no user-serviceable parts on this appliance, says so on the manual.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 13, 2009
Bread not rising as it used to, not sure if problem with paddle or...?
just as a hint - there is few thousand breadmaker manufacturers... each of them is making several models... we do not live with you...
how we can help if we do not know what manufacturer and model?!? telepathy is overrated...
now, paddle have nothing to do with rise of the bread, yeast and temperature do! if paddle is mixing the dough - there is no problem with paddle!
buy pack of new yeasts (dry if you use dry, i prefer live ones), then try bake again, if bake is ok, you solved your problem, yeasts were old and enzymes stop working, if there is no change in results with new yeasts, try use same yeasts in different machine, if result is ok in different machine, you heating element is at fault... time for new machine...
you do not need to be super accurate with your baking, allow little play...
my favourite bread:
3.75 cup flour (non-bleached!)
1.75 cup milk (tepid, body temperature)
2 table spoon olive oil or butter
1 teaspoon sugar
1 teaspoon salt
3 sachets dry yeast (21g - 0.7oz) if live yeast - about golfball size
enjoy!
and do not forget to vote...
Feb 11, 2015 | Kitchen Appliances - Others
Took paddle off to clean but now can't get the paddle to rotate, help?
Add enough near boiling water to cover bottom. Wait 5 minutes. Drain off water. Add oil that you would use to make next loaf of bread. Rotate paddle back and forth to loosen up. I always add oil first to "lube" paddle shaft.
Apr 30, 2014 | Kitchen Appliances - Others
Kneading Paddle
All bread machines have a final "punch down" of the dough that lasts a few seconds before the final rise stage. When "punch down" is over that is when you can remove the dough ball, remove the paddle, set it aside and place the dough ball back in the pan. It usually helps to have your hands dusted with a little bit of flour.
Apr 21, 2013 | Morphy Richards Kitchen Appliances -...
Paddle problems.
All bread machines have a final "punch down" of the dough that lasts a few seconds before the final rise stage. When "punch down" is over that is when you can remove the dough ball, remove the paddle, set it aside and place the dough ball back in the pan. It usually helpsicon1.png to have your hands dusted with a little bit of flour.
Apr 21, 2013 | Morphy Richards 48280 FastBake Bread...
How many pounds is xl bread
an xl loaf would be determined by the amount of flour you use. a standard 2lb large loaf is made usingc 560gms (19.7ozs)flour. i make my loaves using 850gms (30ozs) flour. the end result is an xxl loaf. (i don't bake it in the bread pan. i have an extra large loaf tin. one thing to note, is when using more flour all the other ingrediants apart from the yeast need to be increased too . good luck.
jackie
Feb 16, 2013 | Panasonic SD-2501WXC Automatic Breadmaker...
I have an Oster Bread maker model # 4811 and the
If it's heating at all, the element is probably good. If it is cooked partway, but not fully, that could be because it isn't rising. Make sure the dough is the right consistency before baking, as a different flour could have a different moisture content, thus requiring a different amount of water. Make sure there is sugar in the dough for the yeast to "eat" or it will not rise. If all else fails, try other yeast. Your can also test the yeast by proofing it. Put a teaspoon of the yeast in a cup of warm water with a teaspoon of sugar. It should foam and bubble in 5 minutes or so. You can find more detailed directions on testing the yeast by searching "proofing yeast" on a search engine. Good luck.
Jan 24, 2010 | Microwave Ovens
My chefmate breadmaker - The liquid and flour don't get mixed..
Even though you hear the paddle moving, the belt may be slipping so the paddle does not rotate at full force. Please check the tension of the belt. You can access the motor, belt, pulley assembly inside the base of the machine. Also, please check to make sure the kneading cycle is run fully. Check the manual to see length of cycle. Good Luck...Hank
Jan 22, 2010 | Chefmate TR 7000 Bread Maker
Every time I bake a wholemeal loaf, it bakes well enough, but it tapers off to one end. This problem does not seem to occur with white bread, which rises evenly throughout the length of the loaf.
Fast Action Easy Bake yeast is supposed to help with improving the volume of a loaf, but you can add 1/4 tsp of Vitamin C powder (ascorbic acid) to whole wheat loafs to improve the rise. Sometimes mixing the flours helps as a small amount of white (30%) can make the loaf less dense. Make sure you use the best quality flour you can afford - the cheap ones don't always make such a good loaf.
Jul 14, 2009 | Panasonic SD-YD205 Bread Maker
I have a problem with uneven shaped loaves
The paddles fit two ways, so what you must do is have them facing opposite ways, then they fight with each other and elongate the loaf
Dec 30, 2006 | Black & Decker B2000 Bread Maker
Black & Decker B2300 Bread Machine Logo
169 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
