I cant get any software to recognize the webcam. I have downloaded all the recent drivers including those from the acer website, but every time I attempt to install them I'm told that there is no webcam. This also happens when I try and install the acer crystal view software. I initially had the software on my computer but when I opened it it told me there was no webcam and disappeared off my had drive! Has anyone had a simelar issue and if so how did they fix it?
770 people viewed this problem
Go to Device Manager and open up Universal Serial Bus controllers and you should see USB Unknown Device. Right click on the USB Unknown Device and click on Uninstall. Shut down the Aspire One PC. Unplug the power adapter to the PC. Remove the battery at the back of the PC. Wait 1 minute.
Put back the battery. Plug the power adapter. Turn ON the Acer Aspire One pc. It should automatically detect the Acer Webcam and it will be listed in the Imaging Devices at the Device Manager. :) yay
Source: Acer Aspire one "The Acer Crystal Eye webcam has not found!"
For my Acer 5920, I use this - Press Windows Start Key - All Programs. Click on Acer Empowering Technology, which will open list. Choose Acer ERecovery Management. This will take you to a screen where you can select from various Restore options, including Reinstall applicatoins/drivers. Next screen is Contents or Manuals. Choosing Contents will take you to software & drivers, which can be reistalled from there.
Source: Acer Crystal Eye Webcam
I recently bought Acer Aspire 4530 but the camera is not working. the camera is black and it doesnt open even if i change setting regarding brightness and all. I even downloaded Bison 2.0.01.7 and Suyon 2.0.8.1 drivers but when i install those - even it didint work.
Source: Acer Crystal Webcam Not working
try this it sometimes works.
1. Start Registry Editor (Regedit.exe).
START > RUN > (Type) REGEDIT (and hit ENTER)
2. Locate the UpperFilters and LowerFilters value under the following key in the registry
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6BDD1FC6-810F-11D0-BEC708002BE2092F}
Write down the upper & lower filter valuse.
Delete the UpperFilters and LowerFilters value (it's safe, and if could be restored later on if you have written it down, so don't worry)
Source: Acer Aspire One AOD250 Netbook Built-in Webcam problems....
maybe the webcam isn't compatiable with the program you are using
Some newer cams are not compatible with Yahoo, check here to make sure yours is. If not (too new) then try a 3rd party software to run it through... I've used a free fun one called 'ManyCam' , if you run your laptop cam through that it should work on yahoo messenger.
Dave
Source: acer crystal eye webcam cant use in yahoo messenger
I have an acer aspire 9300laptop. i formated my laptop and i installed the windows vista instead of xp that i used to...
I am unable to find my webcam under device manager, imaging devices.I downloaded drivers USB2.0 PC Camera - Chicony...
i cant open the acer eye crystal webcam on my laptop Acer Aspire 2920Z, if open the camera directly go to the page...
The optical drive on my computer has power but always reads as an empty drive. Windows identifies it but not the disk...
vikash_lvj For Acer aspire V3-571 everything is good but i would like to download this model crystal eye webcam driver could u plz send me the link where i could get downloadable file
Mar 02, 2013
