Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
My dishwasher does not drain the water out it stays in the bottom
The washer started washing but when time to drain out it stay in , what went bad
  • ddk4c Dec 21, 2008
  • car16ole Mar 22, 2009
    When I run my dishwasher, the water comes up in the sink, which slowly drains away, but then after washing there is water in the bottom of the dishwasher
I had this same problem on a different model LG. The manual will tell you to check the drain hose. Other "reviews" on the web will tell you that they have replace the main board, motor assembly, and other parts ($$$$). Check the hose first to make sure it is not blocked. On mine I also removed the internal spray unit to make sure nothing had blocked the drain from that direction. The solution to my problem came from another FixYa responder who said that on some of the models before 2007, they had a problem with wires inside the door. Take off the door panel and check for broken wires. The inside door panel has a tar type insulation. On mine one of my wires was in the tar and had actually broken. I soldered it, insulated it, and it now runs fine. Hope this helps.
Posted on Jan 22, 2009
A lot of water stays at the bottom(in fact) of washed dishes(crockery) What do I have to make?
There is a drain screen on the bottom of the dishwasher that needs to be cleaned out on a regular basis, especially if you put in dishes that haven't been rinsed off. Food waste will plug up the screen and not let the water drain out fast enough
If that screen gets blocked, the water doesn't have enough time to be drained from the washer during the timer sequence and the water will remain at the bottom.
Mar 06, 2015 | Miele Incognito G858SCVi Built-in...
Smeg dishwasher problems
Check the screen, which is under the bottom wash bar. You need to pull out and clean and then see if it will drain. Also listen to make sure the drain motor is running, it also could go bad on you.
Aug 25, 2014 | Smeg Dishwashers
Water stays in bottom of dish washer
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Apr 18, 2011 | Maytag Washing Machines
Water is staying in the bottom
Water staying in bottom is not a problem unless the dishwasher base is full of it and covers the wash arm.
This means the drain cycle is not working or dishwasher is shutting off before drain cycle.
Try to clean the filters at the base and check drain in kitchen sink side is clear.
Need the model number in case you want more specific instructions.
Dec 06, 2010 | Maytag Dishwashers
Can not hold wash temps at 150 degress F.? Once filled the resorvior tank stays filled, but water continues to run out main drain?
If it's drain water and filling with water at the same time your drain hose is lower than the water fill line of the washer. try raising the drain hose up higher
Jan 26, 2010 | Hobart 42 in. AM14C-154 Free-standing...
Dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
May 30, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
Stays in wash cycle Whirlpool Dishwasher Du1050SS
the stat is mounted to the bottom of the tub it will read closed if good if it reads open replace it
May 03, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Kitchenaid dishwasher
Motor bad. If you are getting power to the motor then the motor is bad.
Mar 31, 2008 | KitchenAid 24 in. KUDS25 Built-in...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
1,160 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
