Question about Interactive Health iJoy 100 Robotic Massage Chair Black FR
Ijoy 100 does not go up and down
When you hit the lower back function, it bucks a few times and turns off. It functions in the upper position fixed and goes through the roller motions correctly. It turns off in all program modes in about 10 sec.
  • ronluke Dec 23, 2008
    FYI, my girl bought the IJoy 100 for me for christmas at Linens and things in their deep discount, going out of business sale. All sales final. Needless to say, she was balling her eyes out when she found it less than perfect when fully gone through. I am Mr. Fix it. Trust me, I am the perfect guy to give a fu€ked up piece of equipment to fix and truly appreciate how much you saved on it!!
    I further investigated the sitch and found a bent screw shaft,2 broken mounts, and a broken sensor. Some idiot must have dropped something on its back bone in the store. Note to all. It is fairly fragile, apparently.
    It's fixable, but the zippers don't work on the back. I opened it from the front by cutting along the stitching in the front, under the outer zip cover. After my discovery, I called IJoy themselves and were very helpful. I am purchasing the "all in one afixed roller assembly attached to the back wooden plate with all connecters and sensors for only $125+ shipping. Not bad, since I am not a dealer/ warranteed refurbisher etc...
    The only problem for me is the stitching after having to do major surgery to this beautiful piece of luxury equipment. This ***** never gets tired or cramped hands, like I do giving a massage,LOL.
    BTW the frickin' foot and leg massager is mint! I have chronic foot pain from 20 years on ladders hanging gutters and powerwashing, gaining 25 lbs in the last year etc... You have to get one.
  • Anonymous May 17, 2009
    "Hands" stuck at top of chair and won't go down.
Steering column top bearing replacment
double posted, with 1999 added.
the FSM says dont reuse steering wheel bolts.. (unique)
here is an online quote to get to the combo switch
quote;
Removal & Installation
  1. Disconnect and isolate the battery negative cable. WARNING(bags can kill, my comment)
    Wait two minutes for the airbag system reserve capacitor to discharge before performing further diagnosis or service.
  2. From below the steering column, remove the three screws that secure the lower steering column shroud to the multi-function switch mounting housing.
  3. Using hand pressure, push gently inward on both sides of the upper shroud near the parting line between the upper and lower shrouds to release the snap features that secure the two shroud halves together.
  4. Remove both the upper and lower shrouds from the steering column.
  5. Remove the Steering Control Module (SCM) from the steering column.
  6. Remove the two screws that secure the left multifunction switch to the SCM .
  7. Disengage the two retaining tabs , next to the screw mounts that secure the left multi-function switch to the SCM.
  8. Disconnect the left multi-function switch from the SCM.
To install:
  1. Position the left multi-function switch onto position on the Steering Control Module (SCM) .
  2. Engage the two retaining tabs, next to the screw mounts that secure the left multi-function switch and firmly snap into place.
  3. Install the two screws that secure the left multifunction switch to the SCM. Tighten the screws to 22 inch lbs. (2.5 Nm).
  4. Position the lower steering column shroud to the underside of the steering column.
  5. Install the three screws that secure the lower steering column shroud to the multi-function switch mounting housing. Tighten the screws to 17 inch lbs. (2 Nm).
  6. Position the upper column shroud over the steering column with the hazard warning switch button inserted through the hole in the upper shroud.
  7. Align the snap features on the upper and lower shrouds and apply hand pressure to snap them together.
  8. Reconnect the battery negative cable.
Dec 22, 2013 | 1999 Jeep Grand Cherokee
2001 jeep grand cherokee laredo, lights come one intermittently, horn came on unexpectedly and wouldn't turn off. How do I fix that?
Lights intermittent can be caused by switch or relay. Try swapping the Low Beam relay with another similar relay (horn relay is a good choice) to see if that resolves it. These relays are in the Junction Block--may be under the hood or in the car but not in the big box by the battery). If this doesn't fix it, the problem is likely the headlamp switch.
Horn coming on is usually caused by a broken switch or stripped wire insulation inside the steering column. You would usually have to take the steering wheel off to fix it, and this requires special tools; however, if the problem happens to be under the steering column shroud, you may be able to fix it without taking off the steering wheel. Take the shroud off and see if you can follow the black/red horn wire. Follow it as far as you can to check for stripped insulation contact with any metal. If you lights switch is bad, you can also change that while you have the shroud off.
Please let me know if you have questions.
Wand Removal & Installataion
  2. Remove the knee blocker from the instrument panel.
  3. Remove the three screws that secure the lower steering column shroud to the upper shroud.
  4. If the vehicle is equipped with a standard non-tilt steering column, loosen the two upper steering column mounting nuts. If the vehicle is equipped with the optional tilt steering column, move the tilt steering column to the fully lowered position.
  5. Remove both the upper and lower shrouds from the steering column.
Fig. Steering column shroud removal for the Cherokee
  1. Remove the two screws that secure the multi-function switch water shield and bracket to the top of the steering column.
  2. Remove the one screw located below the left multi-function switch control stalk that secures the multi-function switch water shield and bracket to the steering column.
  3. Gently pull the lower mounting tab of the multi-function switch water shield bracket away from the steering column far enough to clear the screw boss below the left multi-function switch control stalk.
  4. Lift the water shield and bracket with the left multi-function switch off of the left side of the steering column far enough to access the two instrument panel wire harness connectors for the left multi-function switch.
    NOTE If the vehicle is equipped with the optional tilt steering column, lifting gently upward on the tilt release lever will provide additional clearance to ease left multi-function switch removal.
  5. Disconnect the two instrument panel wire harness connectors from the left multi-function switch connector receptacles.
  6. Remove the left multi-function switch and water shield from the steering column as a unit.
  7. Gently and carefully remove the water shield from the switch by pulling it over the hazard warning switch button and the left multi-function switch control stalk.
To install:
  1. Gently and carefully install the water shield onto the switch by pulling it over the hazard warning switch button and the left multi-function switch control stalk.
  2. Position the left multi-function switch and water shield near its mounts on the steering column as a unit.
  3. Reconnect the two instrument panel wire harness connectors to the left multi-function switch connector receptacles.
  4. Position the left multi-function switch onto its mounts on the left side of the steering column.
    NOTE If the vehicle is equipped with the optional tilt steering column, lifting gently upward on the tilt release lever will provide additional clearance to ease left multi-function switch installation.
  5. Position the lower mounting tab of the multi-function switch water shield bracket to the steering column screw boss below the left multi-function switch control stalk.
  6. Install and tighten the one screw located below the left multi-function switch control stalk that secures the multi-function switch water shield and bracket to the steering column.
  7. Tighten the screw to 10 inch lbs. (1.1 Nm).
  8. Install and tighten the two screws that secure the multi-function switch water shield and bracket to the top of the steering column [Tighten the screws to 20 inch lbs. (2.2 Nm)].
  9. Position both the upper and lower shrouds onto the steering column.
  10. Install and tighten the three screws that secure the lower steering column shroud to the upper shroud. Tighten the screws to 18 inch lbs. (2 Nm).
  11. If the vehicle is so equipped, tighten the two nuts that secure the non-tilt steering column upper mounting bracket to the dash panel steering column support bracket studs. Tighten the nuts to 200 inch lbs. 22 Nm).
  12. Reinstall the knee blocker onto the instrument panel.
  13. Reconnect the battery negative cable.
Nov 04, 2010 | 2001 Jeep Cherokee
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
Image runner c5870 error E0008-0001. How can i solve this problem?
that error happend because the last time the fixing assembly was rebuilt and or replaced the counter wasn't reset. what you need to do is go into service mode and clear the counter for the upper fixing roller and lower fixing roller.
to get into service mode you need to hit the additional functions key
the 2&8 at the same time
then the additional functions key again
this should get you in service mode even though there is an error code....if it doesn work the first time you try it shut the machine off and turn it back and try again. once into service mode
you need to hit the copier button....
then go across to the last tab .....counters...
click on it then click on drbl-1
then you will scroll down till you see
fx-up-rl click on it then hit the C button on the control panel where the numbers are and it should reset it back to 0
and then you need to click on
fx-lw-rl and do the same with it
fx-ex-rl and clear it as well
then you should be able to turn the machine on and off and it will come back to life
Jun 19, 2010 | Office Equipment & Supplies
Kneading, compression and percussion do not work
(youstop) were you able to find or replace this plastic gear? get it fixed? thanks
Dec 28, 2008 | Interactive Health iJoy 100 Robotic...
E00002-0000 error code
ont. Panel, press the following, one after the other, * (additional functions), 2, 8, * (additional functions). You are now in Service Mode. Touch the Function Tab, touch the Clear button, touch the ERR button, when it is highlighted, press the OK button at the botton of screen. Power Cylce unit. If it comes back up, may have been a fluke. However, if it comes back, check your Fixing Assy for jammed paper, or damage to the Fixing Film (Upper Roller). Replacing the Film is not hard. After you remove the Fixing Assy., its a couple cables and springs. Rather on the easy side for Film replacements. Remebmer, on these models, the Film is also the Heater and Upper Fixing Roller. The Film is most likely on the pricey side for new, believe you can find rebuilds. Just keep in mind that the Film is still a lil' bit cheaper then the whole assy., and 8 out 10 times, its the Film that fails in the asssy
Mar 21, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Keyboard stuck in upper case
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
Casio calculator MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Jun 11, 2007 | Casio MS-80TV Scientific Calculator
Interactive Health iJoy 100 Robotic Massage Chair Black FR Logo
389 people viewed this question
Top Interactive Health Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Interactive Health Health and Beauty Expert? Answer questions, earn points and help others
