Question about GE DPSR610GGWT Dryer
GE Electric Dryers Automatic Cycle won't advance/turn off
My electric dryers automatic cycle won't advance, therefore, turn off. The timed setting works fine. The heat works fine as I just use the timed cycle until I get the automatic cycle fixed. The dryer is about 8 years old. I found this problem after I set the dryer at night and found it still running in the morning. The dryer was hot to touch but not so hot it burned. I figured this was due to running for 8 or so hours straight. Any help would be greatly appreciated.
  • 1 more comment
  • korys23 Jan 17, 2009
    I am having the same problem, it runs and heats fine just when in the Automatic Cycle the timer never advances therefore just keeps running. But when set on timed dry it will shut off like normal.
  • Anonymous Mar 16, 2014
    When using the "Timed" cycle we can no longer adjust the time up or down. It is stuck on 10 minutes not the default 40 minutes. We can still adjust the time when using the "Custom Refresh cycle". So i don't think there is a problem with the + and - touch pad.
  • Anonymous Mar 22, 2014
    Electric dryer not hot on auto cycle
  • 71 Answers
Check the vent probly cloged or vent hose kinked, or heater is broken.
Posted on Dec 21, 2008
Timer doesn't work
If you are saying the timer does not advance then it is probably a bad timer. However you may have another problem if it is just the automatic dry cycle that doesn't work. Most timers have a time cycle with minutes. If that works but the other auto cycles do not work, then one of the temperature sensors is not working. If the time cycle doesn't advance at all then the drive motor on the timer is bad. Complete timer needs replaced.
Jun 10, 2014 | General Electric DHDSR46GGWW Gas Dryer
My Kenmore HE4 electric dryer runs for 2 minutes and stops
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replac it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Oct 01, 2013 | Kenmore Elite HE4 Electric Dryer
My dryer quit heating and at the same time does not stop at the end of the cycle. Just keeps running. Is there something I can do to fix this problem?
If its on automatic cycle the timer won't advance if theres no heat. It will advance on timed cycle, though.
Sep 21, 2011 | Kenmore Dryers
Does not heat, automatic timer when out first
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 17, 2010 | Kenmore Dryers
Dryer won't shut off automatically
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Thank you!
May 09, 2010 | Maytag MED5800TW Electric Dryer
Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Apr 20, 2010 | GE DWSR483EB Electric Dryer
No heat during either drying cycle automatic
heatman101
Feb 15, 2010 | GE DVLR223 Dryers
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
The timer on my dryer does not work.
Hi, If the dry is heating and neither the automatic or the time cycle will advance, you will need to replace the timer. You can test the timer by removing the rear panle and locate the 2 black wires on the timer motor. While the dryer is running, check and see if there is 120V going where the black wires attach to the timer contacts.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Maytag PYE2300AY Electric Dryer
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
GE DPSR610GGWT Dryer Logo
647 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
