Question about Epson Stylus CX3200 All-In-One InkJet Printer
I just changed my cartridges and now it won't print.
I can't do the nozzle check or anything to print.
  • 3 Answers
If the status monitor has red 'X' on the carts then take each out and wipe your finger over the chip, 1 finger for one chip - dont reuse the same finger. reinstall them and try again - if that dont work change them for new -
NO MATTER WHAT PEOPLE SAY ITS BOTH EPSON AND COMPATABLES THAT HAVE THIS PROBLEM
- had epson printers and used compatables for around 8yrs with no real problem (till now - see my post!)
Posted on Dec 29, 2008
I've installed color cartridge but it won't print in color
Try to re-insert the color cartridge into the printer and make sure it is properly seated in the cartridge carrier.
If that doesn't help, try to clean the print nozzles. Please follow the steps below:
1. Press Copy. 2. Press Options until Maintenance appears on the display. 3. Press the right arrow until Clean Cartridges appears on the display. 4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles. 5. Print your document again to verify that your print quality has improved.
Oct 22, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have a PIXMA iP4300 and just want to use it for black and white document printing. My 'M' and 'C' color cartridges ran out a while ago and I disposed of them but didn't replace them...
Most of the Canon printers form the PIXMA iP series block printing when one of the cartridges is empty. You have some options: 1) change the cartridges (with original or compatible) 2) buy a chip resetter and reset the empty cartridges chip so they can cheat the printer that they are full. This way you will clog the nozzles of your print head and the printer will become useless and won't print.
That's why I suggest you to but even cheap compatible cartridges and replace them.
Hope this helps. Alex
Sep 11, 2011 | Canon Office Equipment & Supplies
It won't print.. it goes thru the whole process and makes you think its printing but when its done the page is blank.. I have the Dell AIO 964 printer and all of a sudden it will not print.. it has...
if the unit has been working properly for sometime and then suddenly stopped printing anything... you might try to perform a maintenance cleaning on your unit... this is caused by clogged nozzles which stops the printer to withdraw ink from its tank.... best way is to perform a headcleaning process for sometime.... if it still persist, reseat the ink cartridges... if it still does not work... try spraying the nozzle with wd40.... let it dry for 1 hr or 2.. if it still persist and the process is the same... im a afraid that we may need to have your printer serviced.... hope this helps you out...
have a grand day...At least we tried...:-)
Aug 07, 2011 | Dell 922 All-In-One InkJet Printer
Printer worked fine until yesterday changed ink cartridges now black wont work tried all options
Hello
well changing the cartridges will not effect anything to the printer but the duration taken for replacement will. As in epson if you leave the printer without cartridges will clog the head nozzles. Did you remove the cartridges and turned off the printer and left idle for sometime? if yes then follow the instructions below
1. Print nozzle check test print to know which nozzles are not working
2. Head cleaning from the printer software.
3. Perform step 1 again to see the difference after cleaning
IF NO
Then you have to take the print head out of the printer and clean the nozzles by using hot water in the Syringe and blowing the derbies out of the nozzles.
Jul 17, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Changed from cartridges to cont. ink system. Now
Hi Dave,
Chances are the problem is that you haven't removed the travel plugs that allow air into the reservoir part of your CIS. This is vital because the air needs to replace ink used up in printing and if it can't do this the air creates something of a vacuum that holds back the ink.
Also worth checking that you haven't got any crimped (folded) tubing or clamps that are still engaged that shouldn't be.
Hope that helps..
Mar 26, 2010 | Epson Stylus Photo 2100 InkJet Printer
Canon i250, black text won't print, but ok with nozzle check
Canon i250. Instructions on this website solved the problem of flashing green and orange lights, but now the black won't print. Changed ink cartridges, but still no print. Did a diagnostic nozzle check, and the black DID print. What do I do now?
Oct 21, 2009 | Canon i250 InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
