Question about Gigabyte GA-8S648FX Motherboard
I have a gigabyte 8s648fx mobo and a 800 fsb 3.0ghz pent 4 northwood cpu. The machine will not dislay as 2 cores in the device manager. So it does not seem to be hyperthreading. Is there something else i need to do in bios or someware to allow hyperthreading? Is does not seem to run the speed that it should be. Darren
    President:
  • 1,179 Answers
Hyperthreading needs to be enabled in bios. Hope this helps.
Posted on Dec 21, 2008
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Does the GA-8I945P-G supports the Core2duo Processor?
No since this is a older mobo the manufactre only recomndes you use Pentium D, Pentium 4 HT, or Celeron D. many people have tried this and have had alot of problems and little success.
May 04, 2011 | Intel Gigabyte GA-8I945P-G Dual-Core CPU...
Need specifications for Intel PM-865G1 mobo
Specifications
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.2GHz and higher speed
Memory Speed/CPU FSB Support Matrix
FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
• Intel® 865G Chipset
- Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
- Integrated graphic controller.
- Supports PC2100/PC2700 /PC3200 memory.
- Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
• Intel® ICH5 Chipset
- AC'97 2.3 interface
- 8 USB 2.0/1.1 ports
- 2 channel Ultra ATA/100 Bus Master IDE controller
- SMBus 2.0 support
- 2 serial ATA Host Controllers
- Integrated LAN controller
• Support 100(Northwood only)/133/200MHz
• Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
• Supports two 64-bit wide DDR data channels.
• Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
mode and 6.4GB/s(DDR 400) for dual-channel mode.
• Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Three PCI 2.2 32-bit Master PCI Bus slots.
- Supports 3.3v/5v PCI bus Interface.
• One CNR slot
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
• AC'97 link controller integrated in ICH5
• 6 channels software audio codec C-Media 9739A
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via 3-pin SPDIF bracket only.
• Intel 82562EZ
- Integrated 10/100 Ethernet MAC and PHY in one chip
- Supports 10Mb/s and 100Mb/s auto-negotiation operation
- Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
Apr 27, 2010 | Intel Motherboard
Best/Fastest CPU for DFI PE21-EL mobo
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
Intel Celeron processor
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Dec 26, 2008 | DFI PE21-EL Motherboard
Cpu upgrade
where are you getting your CPU from you cant just buy any CPU laptop cpu's are made for laptops only and a desktop CPU wont work in a laptop. also what is the FSB of you original cpu if its 400 or 533 it probably wont take a processor that need 800mhz fsb
Nov 24, 2008 | Toshiba Pentium 4, 2.88 GHz (P000382340)...
Wont post with 1333 fsb
This board wont take a 1333 cpu. The fastest it will run is 1066
This motherboard supports the latest Intel® Pentium / Celeron CPU in LGA775 package with 1066/ 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond.
Make sure your RAM is DDR2 800mhz
The Pentium D830 runs at 800fsb which is in line with the board capabilities.
Feb 24, 2008 | ASUS P5ND2-SLI Deluxe Motherboard
Motherboard Issues.
go on new egg.com look up right what u need show whol bunch atx ones with ducl ch asus makes good one thats suports your cpu soket
Jan 19, 2008 | Computers & Internet
New processor
Usually you can use Northwood-core CPU-s on mobos with Willamatte-core CPU. But is important (exept core) - FSB support of your new processor. Which model of your CPU? What the mainboard use (model)?
Nov 15, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
MSI MS-6534
see this official cpu support for your board, you can go upto a 2.8ghz northwood P4 cpu http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=299&maincat_no=1#menu
May 15, 2007 | MSI MS-6534 (6534-010) Motherboard
Gigabyte GA-8S648FX Motherboard Logo
94 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
steyr1
pankaj rautela
pankaj rautela
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
