First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
SOURCE: i forget my security privacy
Hello s_a_rocky,
Remove the sim-card and switch on the phone .. and press this code *2767*2878# .. the phone will restore the factory settings.
Thank you for using FixYa.
SOURCE: want to lock phone but don't know the current
Hello. Take your phone into your phone store and they will change the password for you. Just be prepared to prove that it is your phone. For example, bring in a phone bill. Regards, Joe
ps - kindly rate my answer as helpful. thank you.
SOURCE: i forget security privacy lock code of samsung SGH Z240 mobile
Hello s_a_rocky,
SOURCE: I can't manually install java
dear frnd,
try from getjar.com or with pc suite..hope u will get some....manually your handset doesn't support
njoy n cheers
