Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
SOURCE: PUK code for NOKIA 6020
Your nokia 6020 doesn't have problem. It's your sim card. If you still have your simcard packaging, the PUK code is written their inside it's brochure. Or you can also go to your mobile phone network and ask its PUK code. Or simply buy a new simcard with the same network company. Thank you
SOURCE: My pin code is blocked. Need Puk code. Pls help
The PUK code is a code associated with the SIM card and not with the phone.
You have only two ways to get rid of the PUK code. Either you replace
the SIM card , or you call phone provider that issued the sim cadr (eg.
At&T, Virgin, Tmobile , Vodafone, Telecom etc.)
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the PUK code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
SOURCE: my pin code is blocked and i forgot my puk code
Finding a PUK (Personal Unblocking Key) number is not tough task. To find a PUK code all you have to do is call up customer care and ask them to help you with the issue. Before they provide you the PUK code, they will ask you several questions. You need to give them the appropriate information. Customer care are the only source from which can give you the PUK code.
At the time when you enter a wrong pin number three times. The phone asks you for a PUK number. The PUK code is generally eight digit number This PUK number is an unlocking code which helps you to unlock the cell phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to get a new simcard. This might happen that your phone might ask you for PUK2 after you enter your PUK number.
SOURCE: DEFAULT PUK CODE AND PIN CODE FOR N73 ME
No the Default PUK and PIN codes are not set by you, these codes are Service Provider Dependent (SIM)
All you have to so is to call your Service Providers Customer Support (Like of T-Mobile, AT&T...).
And ask them about the PUK and PIN code, they will first Authenticate few things about the Ownership of the SIM card, and will give you the codes, in return.
I Guess, the picture is clear in front of you, Now.
Regards,
Waqar.
SOURCE: I have a Nokia RH-121 and have blocked the pin how
You need to get the puk code from the phone company you are with. Sometimes you can get it by going into their website depending on the Company.
