Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Both gas lines are dry rotted off...
Looking for a close up photo of lines from carb to gas resevoir.
  • RMA127 Jan 25, 2009
    I have the same problem. I bought the tubing from Home Depot and tried to replace it myself, however it looks like the tubing has to route through a hole in the tank and then attach to a weight in the bottom. I think I may have done this right but not sure, it fires up and runs but i'm afraid i may have attached the weight to the wrong part? I t would be nice to see what it should look like inside the tank.
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello,it would be nice to know what you are talking about,such as brand,model#,type#of machine in question.it's kind of hard to read between the lines,let me know.
Sorry about the delay.
Problem solved, I hooked up the lines (very important to get a drill the size of your new gas line, it aids in sealing the tank, thus providing a good seal for the prime).
The thing in the bottom of the tank, attached to the line is a filter. It is available at any small engine shop).
Once I hooked up the lines and hit the primer ball a few times you can see the fuel moving, you will know, because you will see which way it flows through the lines. The other line is just a return line into the tank.
It is the same on generally any 2 cycle blower or weedwacker motor.
Posted on Feb 15, 2009
My craftsman chain saw 18 will not start
The 3 things needed for an engine to run:
1. Compression (Cylinder, Piston, rings, gaskets)
2. Ignition (Spark plug, ignition module/coil)
3. Fuel (Fuel lines, Carburetor, gaskets, bad fuel)
More than Likely I would start by checking fuel related since that is usually the biggest offender (fuel lines broken/dry rotted, bad carb.)
Jun 19, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Weedeater manuals
The diameter of the fuel lines are bigger then the holes in the fuel tank. Make sure u get the right diameter fuel line. The fuel lines are basically crimped by pressure. Sometimes its like there welded in place. There should be two fuel lines. One is short goes from carb to tank. When you use the primer bulb it takes fuel from tank through carb spits it back into tank. The longer one has the fuel filter on it. Empty all the gas from tank. Look inside of tank with a flashlight and try to locate the fuel filter. Take a piece of wire make hook on one end. Try to snag the fuel filter and pull out. Might as well replace filter while it is out. Take a pair of long nose pliers and grip the hose as close to the hole as possible. Try to pull with even pressure(no yanking). The lines may break because they could dry rotted. Make sure to hook lines back up the same way they came off carb.
Feb 01, 2014 | Weedeater Garden
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
My fuel lines dry rotted, what is the correct configuration for the lines
Fuel hose from the tank with the filter on the end goes to the fuel inlet on the carb ( nearest to the pump cover held eith a single screw ) then tak a pipe from the other cinection on the carb to the short conection on the back of the primer ( suction side ) then tak a pipe from the longer conection on the primer ( pressure side ) back to the tank, the primer pulls fuel from the carb and dumps it back to the tank.
Apr 07, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My timmer wont start. Replaced fuel lines and now nothing. It ran before the lines dry rot.
If the lines dry rotted, some of it probably go into the carburetor. There is a very fine mesh screen inside the carb that traps this sort of trouble. Take the carb off and remove the cover on the end of the carb that doesn't have the hole in it. Find the screen underneath the fuel pump diaghram and clean it with non-flammable brake cleaner spray. This is a very common problem on all these machines....
Aug 15, 2010 | Craftsman 25cc Gas Line Trimmer
My weed eater is leaking gas, and i dunno where from
your fuel lines are probably old & brittel they are the first thing to leak on those sometimes they leak around the tank but they are really thin lines & they get hot from engine heat & dry rot easly replace both lines from carb to tank & the leak will be gone most lines are 1/4 lines in most cases
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
I have a John Deere 116 not getting gas to the filter or carb
It shouldn't have a electric fuel pump. What I would do first is take the gas tank off. Take the fuel line off. Drain the gas tank. blow thru the fuel line.put all back on and fill with gas and try again. I'm guessing it sat for awhile. when gas sits for awhile it gets tarnished.any little bit od debris that was in the gas tank could plug the fuel line. Hope that helps You out.
May 25, 2009 | Garden
Which fuel lines conncets to the carburetor?
Well I finally got my saw running - it occured to me that my older chainsaw never had a primer bulb - so I bypassed it and...pull started it with the choke on till it chugged - then turned the choke off and held the gas full on - pulled the starter cord and was cutting trees - LOL
I did speak with a small engine guy - he explained that the primer is to pressurize the gas tank - so your return line from the carb goes to the suction side of the primer bulb - output to the tank - and pickup line with filter goes to the intake of the carb - FYI - hope it helps ya!!!!!!!!!!
Mar 18, 2009 | Garden
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
446 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
