NSIC (National Small Industries Corporation) is a government enterprise under the supervision of Ministry of micro, small and medium enterprises (MSME). It has been constituted to promote and help the MSME industry by proposing many schemes such as single point registration of government purchase, marketing support and more. It helps MSME business players to grow their business and market effectively.
Registration Error 3
When a color registration error is detected with coarse
adjustment, or with the main-scan line adjustment.
PU firmware does not notify this warning to CU firmware
at the time of Shipping Mode. Therefore, this status
does not occur in a user environment.
n
2 = Yellow
3 = Magenta
4 = Cyan
Dens Shutter Error 2
DENS SHUTTER ERR
Check 3: Check to see whether the sensor shutter opens and closes normally, by the
MOTOR & CLUTCH TEST of the self-diagnostic function. If the shutter operates
imperfectly, replace the shutter unit.
Hello, E051 0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position. Main cause The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty. Action 1. Connector Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected? a. DC controller PCB (J304) relay connector horizontal registration home position sensor b. DC controller PCB (J304) relay connector horizontal registration motor NO: Connect the connectors. 2. Sensor lever (damage and interference), Sensor Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation? YES: a. The horizontal registration assembly is out of place because of damage to the sensor lever. Replace the sensor lever. b. The horizontal registration assembly malfunctions because of the presence of foreign matter. Remove the foreign matter. c. The sensor is faulty and cannot detect home position. Replace the sensor. 3. Horizontal registration motor, DC controller PCB Is the horizontal registration motor control signal generated by the DC controller PCB? J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal YES: The horizontal registration motor is faulty. Replace the motor. NO: Replace the DC controller PCB.
RERA registration is applied on all real estate projects therefore all builders, real estate developer and entity associated with the real estate project is required to submit RERA registration application with the local authority on their official portal. RERA registration in Gurgaonis introduced to eliminate the chances of any discrepancy, irregularity in real estate development industry. We are the leading consultants for RERA registration in Gurgaon with expert professionals to handle the issue. https://www.gsbtaxation.com/in/rera-registration-in-gurgaon
Entering the Service Mode
There are two ways to enter the service mode.
Method 1: Turn the machine on while pressing the “On Line” key and “Escape” key
together until the above message in the illustration appears on the display.
NOTE: If you switch the machine off, any jobs stored on the hard disk using the
sample print and locked print features will be deleted.
Check first with the user tools to see if there are any jobs stored with these
features
(Menu key - Sample Print, or Protected Print).
SP1-XXX (Feed)
1 Mode No.
(Class 1, 2, and 3) Function / [ Setting ]
1-002 [S-to-S Reg.] Side-to-Side Registration
1 By-pass Table *
2 Paper Tray 1 *
3 Paper Tray 2 *
Adjusts the side-to-side registration by changing
the laser main scan start position for each mode.
[ -10.0 to 10.0 / 0.0 / 0.1 mm/step ] FA
4 Paper Tray 3 *
5 Paper Tray 4 *
6 Duplex *
