Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Black stuff wiping off beaters of kitchenaid mixer
Have you ever heard of such a thing?
If it's just the wire beater attachment, then it's possible it's oxidation from the metal/aluminum. Did you put it in the dishwasher? The manual says not to put the wire beater in the dishwasher. Hope that helps.
Posted on Jan 15, 2009
  • rkwonnell664
    rkwonnell664 Apr 28, 2012
    My tools for my stand mixer have a black coating on them that rubs off on my hands so Im assuming that if they do that on my hands that it is coming off on the food. What is the solution for this? Do I need to throw the attachments away are are they cleanable
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Mixing paddle slips off pin
We have never heard of this problem before. I spoke with our KitchenAid technician as well and he has never seen this problem in the over 20 years of working on KitchenAid mixers.
Are you sure that the beater is hooked on all of the way, and there isn't anything in the beater stopping it from turning and clicking into place? Is the pin stuck? If the pin is not sticking out all of the way, or the spring is bad/damanged it is possible the beater could come loose. You would want to replace the agitator shaft.
Agitator Shaft: http://www.mendingshed.com/kacentershaft.html
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 03, 2013 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid khm3wh beaters will not stay in mixer
I fixed mine (my wife's). Kitchenaid 3-Speed Hand Mixer KHM3WH. Here's how I did it.
This is a pretty old mixer. My wife bought it at a thrift store for $1. She brought it home, we found the beaters and whisk beaters on eBay. Paid $34.00 for both sets of beaters, but when we received them we found they would not stay in the mixer. Oh we also bought the alternative/replacement beaters from Sears, parts online. I don't think those will work with my fix. However with some $0.92 rubber washers from Lowe's and a heavy duty paperclip I fixed the mixer, and it works flawlessly. Maybe some stainless steel wire would be a better, more permanent fix.
Apr 30, 2012 | KitchenAid KHM3 Classic Hand Mixer
My KitchenAid Professional 6 mixer has been used about 2 years. Lately it leaves a black trail in my icing/batter/whatever from the finish being worn off the metal beater--the triangular one. The bowl has...
It sounds like you have two problems. First, the black marks are usually because of a reaction between the beater and certain chemicals used in dishwashers. Try washing the beater by hand and scrubbing it throughly to remove any residue. If this works, don't use the dishwasher again. You could also buy a plastic coated beater.
It also sounds like the bowl height needs adjusting. There is a screw just under the head for this.
Jan 08, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Jan 02, 2010 | KitchenAid KP2671 Professional 6 Series...
My kitchenaid hand mixer beaters knock into each other as they spin. can i fix this?
This happened to me also, and it was because one of the beaters was no longer straight (bent just slightly, but enough). I found a replacement beater at a thrift store, and now it is fine. There were several replacement beaters at the thrift store... I'm guessing because many of the KA hand mixers are starting to die (the beaters don't 'click' in anymore).
Oct 22, 2009 | KitchenAid KHM3 Classic Hand Mixer
Motor runs, beater stopped rotating. Some gear sounds heard before it stopped. Beater will not turn at any speed setting.
drive gear or shear pin stripped. Common on this model. Return to repair centre. Expect to pay approx $150.00 to repair, sorry.
Sep 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Hand Mixer Beater won't stay in slot
You need a new gear set.  Hard to find however.
Jan 07, 2007 | KitchenAid KHM3 Classic Hand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
871 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
