Question about Mitsubishi WD-62531 Projection Television
62" mitsubishi lcd hdtv
The timer light flashes green then stops, goes to a steady green and i get audio for a few secs with a blank screen then the tv shuts off
  • imdatdude Dec 21, 2008
    had the tv for less than 2yrs
    my mitsubishi lcd hdtv wd62531 timer is blinking then it stops and goes to a steady green light gives audio for a few secs with a blank screen and then shuts off, one of your experts says it sounds like overload protection, what should i do next, had the tv for less than 2yrs
    Master:
  • 505 Answers
First of all turn off the TV completely for 5-10 min. let it cool and then turn it back on.
If you are using a surege protector try and connect to a wall outlet or a different outlet.
If the tv still has the same problem its a problem with the Power Control Board\Digital processing Board. The TV needs to be repaired.
Thanks
Posted on Dec 21, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the blinking green light indicates auto protection has kicked in. Pls try:
  • unplug from the mains for an extended period of time;
  • press the System Reset button on the front panel;
  • other possibilities include probable leaky/faulty capacitors.
Good luck and Thank you for using FixYa. Happy Holidays.
  • 106 Answers
This problem could be as simple as a bad lamp. Has thr lamp been replaced? On the front of the tv, push and hold menu and input buttons at the same time for 10 seconds. You will see the timer light start flashing a code. It will blink afew times....pause and blink a few more times. It will vary. It could blink once pause and blink twice. Let me know what the code is and I can help you. Thanks
    Master:
  • 479 Answers
Its just the simple problem of some of the prts on the main board of the tv gets overheated and the tv shuts down .first it gives sound and due to that faulty or weak component on the main board which gets heated it does not gets continued and shuts down. u just need to check out on the main board of your tv for that faulty capacitors or ICs thart has turned bad .u can check this out with a multimeter.and replace the faulty. u can get the new replacement component at  www.radioshack.com just check it out and it will work properly after that.as this is the common problem faced by many customers and it get repaired very easily by replacing the faulty components, thanks.
  • 4,472 Answers
This sounds like overload protection. How long have you owned the television? Once I have more information I can assist you further. Please don't request more information until I can assist you further.
Thanks,
lee
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 TV will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it for a samsung ,it works like your mitusibishi:http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast has a sensor that detects when it's not able to power the lamp or if lamp is not responding,it will flash red when that sensor detects that.When you say: "it began to roll like the vertical and horizontal hold did not work then the sound went out" Do you mean you where getting horizontal lines? If you did that could be the Dmd.his is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Usually when there's a green light it could indicate a problem with the power supply,sometimes some capacitors do go bad. Check all of this and comment on this answer to see how it went.
Apr 08, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I too have a Mitsubishi 62525 with steady blinking green light.
IF YOU UNPLUG SET THE LIGHT WILL BLINK FOR 45 SEC WHEN IT STOP YOU CAN PLAY SET ,IF THIS NOT WORKING CHECK THE LAMP
Aug 24, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 green timer light keeps blinking after lamp replacement
Did you let the green light flash for about 70 seconds? It goes thru a self check when plugged in and takes a little time
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
The TV wouldn't turn on...no power
sounds like you have a bad flyback in your set
Dec 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD 52528 tv
I had the same problem last year - it was, indeed the bulb. At the time the tv was still under warranty and Mitsubishi sent me a replacement bulb.
Dec 27, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-62531 Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
