Question about Maytag MEW6627D Electric Double Oven
Both ovens run about 50 degress hotter than the setting.
Set for 350, runs about 400. Checked with a new Kitchen Aid thermometer which I'm sure isn't that accurate but for sure the ovens are running hotter that the setting. How can I calibrate them or can you tell me which component may be causing this. Thanks.
  • craftldy Dec 22, 2008
    Did this really cost me 10 bucks? I expected a dialog here to help me troubleshoot this problem. This is my wife's email since the site won't work for me anymore. I'm technically savvy. Please get back to me or tell me if I'm misunderstanding something here. Thanks, and my name is Mike.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Normally, there is a temperature prob on one of the walls of the oven. This probe then sends the temp signals to a controller board that compares the reading to the temp setting as selected by the user. IF a difference is computed, then the controller board either continues powering the heating elements or cuts the supply. This heater probe is different from the thermal switch that switches off automatically when a preset temperature (for protection) is reached.
Based on the above, possible cause of your concern would be:
  • faulty thermal probe (most likely);
  • corroded connectors, wiring and terminals (could be visually inspected, easily repaired);
  • faulty controller board (least likely).
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 21, 2008
    Master:
  • 505 Answers
The problem is with the thermostat which is responsible for the heat control. On-Off Control This is the simplest form of control, used by almost all domestic thermostats. When the oven is cooler than the set-point temperature the heater is turned on at maximum power, M, and once the oven is hotter than the set-point temperature the heater is switched off completely. The turn-on and turn-off temperatures are deliberately made to differ by a small amount, known as the hysteresis H, to prevent noise from switching the heater rapidly and unnecessarily when the temperature is near the set-point.
Thanks
  • 4,472 Answers
Most likely it would be the temperature sensors. If you have a thermometer you can just adjust your temperature accordingly and use it that way as most likely it will remain consistent. If you need further assistance let me know. Please take a moment to accept and rate my solution.
Thank you,
lee
  • Lee A.
    Lee A. Dec 22, 2008
    Like i said it most likely a temp. probe problem which you can check/replace and make sure all the connections are good as well.
    Thank you,
    Lee
  • Lee A.
    Lee A. Dec 22, 2008
    How long have you owned the oven? Once I have more information I can assist you further.
    Thank you,
    Lee
Oven runs much hotter than set temperature. Usually 50 degrees hotter than what it is set at, but can go over 100 degrees higher.
Sounds like you need a new oven thermostat or get an oven thermometer and by experimentation draw up a new heating range for the oven dial.
Feb 11, 2011 | Frigidaire Ovens
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
Our ARG7302WW range is missing the temperature sticker for the dial...where should 350 degrees be and does it go up in temp clockwise?
Hello- The background panel is screened with gradients, but is expensive and hard to find. The easiest solution is to purchase an oven thermometer and allow to set for about 20 min at an indicated 350deg. Make sure that dial knob is tight and mark with a line at that point. Use a fine point sharpy, and clean surface before marking. Turn off, let cool, and turn to the new 350 mark and see if temp comes up and matches 350deg on thermometer. If it works ok, try marking 325, 375, 400, etc. ---Yes,  Clockwise is up in temp. Let me know if this info helps.   Have more if needed-  Thanks - Ed
Mar 16, 2010 | Ovens
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Oven temperature does not regulate. The temperature is set for 350 but was 500 degrees in oven according to thermometer. Then sometimes you set it for 350 and it will get to almost 350 and then start...
From the symptons you describe, I would say that the oven thermostat is faulty, and in need of replacement.
Make sure your thermometer is o/k by checking it against another one, or boil some water, and check the temp of the boiling water, this should determine if your thermometer is o/k.
Hope this helps.
Dec 20, 2009 | Kenmore Ovens
Hi..if i set the control knob to 350 for the oven..its goes to 400 or 450 degress..i put a oven termonater in there..its always hotter than what u set it on. model # JBP24G0K2AD or the o is a 0 not sure..
The oven thermostst needs replacing, as it is not sensing the correct temperature, this is the switch behind the control knob
Please rate my solution.
Thanks.
Nov 10, 2009 | GE Ovens
Pizza, banana bread, etc. doesn't get done in the middle.
some oven temperature dials are adjustable by pulling knob off,turning a bit and pushing it back on in a different position.use an oven thermometer to determine the accuracy of your control knob.adjust knob or make note of difference between dial setting & thermometer reading.i.e.knob is at 350* thermometer says 300* set knob to 400* to achieve an oven temp of 350. could you E-mail me a slice of banna bread?
Sep 27, 2009 | Ovens
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 16, 2009 | Ovens
My new oven runs about 50 degrees hotter than the temperature I set, is this normal
No,but it can be calibrated through the control push and hold the Bake button it should come up 0 F you can go plus or minus 35 degrees with the up and down keys.but make sure your thermometer is accurate.Whirlpool will send someone out to check it out for free for the first year.
Aug 29, 2009 | Whirlpool RBD305PD Electric Double Oven
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Maytag MEW6627D Electric Double Oven Logo
60 people viewed this question
Top Maytag Ovens Experts
Carmen Mikulic
Marvin
Marvin
Sal De
Are you a Maytag Oven Expert? Answer questions, earn points and help others
