Question about Toshiba Satellite A105 Notebook
How to safely remove the CMOS battery
I'm hoping by doing that, the factory boot defaults will be restored. I'm working on a Toshiba Satellite A105-4011. It is disassembled down to the MB. The battery holder looks pretty fragile and I don't want to break it. How is this done safely?
Thanks!
  • 4 more comments
  • cst1269 Dec 21, 2008
    Thanks for the quick reply!
    The metal clip looks more like it should bend backwards rather than to the side. I just tried to push it to the side with my fingernail but it didn't want to move. Is it safe to use more force?
    The whole thing lifts up (battery, blue ring, and clip). It appears that there are prongs on the top and bottom of the battery. Do the battery and blue ring slide out from the clip? Or does the battery pop out of the ring? Or, are they all (battery, blue ring, and clip) removed from the MB? Sorry for all the questions, but I can't afford to wreck the MB.
  • cst1269 Dec 22, 2008
    Then my question is: is it safe to lift the clip to remove the battery or will that cause it (the clip) to break? I don't plan on replacing the battery - I just want to remove it and put it back in - the whole purpose is to reset the bios because the only that it boots from now is the Intel Boot Agent. That's with a new HDD. Will that, in fact, reset the bios? I read somewhere that that doesn't work with laptops. With the old HDD it always boots to Express Media Player. I can't get into F2, F8, or F12 - I think there may have been an infection that changed the setting in the bios to prevent a fix.
    Please use this link: http://www.irisvista.com/tech/laptops/To... I'm reassembling but didn't mark one cable - it's the one on the left bottom with a red arrow. The cable is attached to the MB, but where does the other end go? Thanks for all the help.
    BTW, I never did get the CMOS battery out.
  • cst1269 Dec 23, 2008
    OK another question related to reassembly. Where does the other end (not the MB end) of the DVD cable attach? The cable itself is bent on purpose and heads toward the DVD. Or, the other side where the fan is, but I don't see where it might connect on either side!
    Thanks again!
    I found it! It's not the DVD cable as shown in the pic. It's for the power switch on the underside of piece that holds the KB, and is hidden by a piece of protective plastic.
    Thanks for all your posts!!!
  • Toshiba Master
  • 32,281 Answers
The battery is a button type battery, you can release by pressing the metal clip to the side and the battery should pop up, if not use a thin blade screw driver to lift the battery up whilst pressing the metal clip to the side, Do not hold the battery (top & bottom) with metal tweeters, you will create a short circuit condition.
Posted on Dec 21, 2008
  • 2 more comments
  • Chris Hingee
    Chris Hingee Dec 21, 2008
    You can apply a bit of force, use a thin sharp blade and lift it up from the opposite side of the metal clip.
  • Chris Hingee
    Chris Hingee Dec 22, 2008
    The blue ring and clip is not part of the battery. Various manufacturors use slightly different methods in fixing the battery in place.
    Just make sure you put the new battery back the same way.
  • Chris Hingee
    I'm not 100% sure, the clip may pop out with th battery, try and get a copy of the manual off the Toshiba WEB site (use another computer if you have to) or ask their Tech Support.
    To get into the BIOS, on a cold boot up press DEL, if that doesn't try F1 or F2. Once you get into the BIOS there may be an option to restore default settings.
    When you remove the battery it will take 1/2 + hour for the battery charge to discharge from the BIOS chip for it to reset. You can speed this up by using a paper clip to short out the + and - terminals of the battery clip. I suggest you check the voltage of the battery with a multi-meter and if it less than 3.0 volts then it should be replaced because the battery is nearly flat.
  • Chris Hingee
    Chris Hingee Dec 23, 2008
    Can't advise you but generally just trace the other end of the cable, the way the cable is laid out, the end will be near the appropriate connector. From the image the cable looks like a flat ribbon cable and most likely does not have a connector at the end. This type of cable slips into a connector and is locked in by a slide catch. You need to slide the catch out, insert the cable and slide the catch back in to lock the cable into the connector.
Bios menu password prompt get invalid entry
If its the bios password.
You may try to open-up the case and remove both the laptop battery and the CMOS battery inside to try to reset it to default and see if it gets cleared-up.
Otherwise the best way is to take it to Toshiba service center to resolve the issue as some BIOS are lock totally that they do not rely on the said CMOS battery anymore to store data. So they would need to literally access their ,main board for reset or if worse, it may even come to the need to replace the board itself.
Either way, In today's gadgets I recommend to make sure you have a copy of your passwords for BIOS, System and Log-in for safe keeping all the time.
Aug 19, 2014 | Toshiba Satellite C55-B5202 16-inch Laptop...
Toshiba 1070 bios satellite password
This is supposed to be impossible, but there is a way to do it. Unscrew the case, locate the CMOS backup battery, remove it. Leave it out for a minute or so as to allow the capacitors enough time to discharge. Restore the CMOS battery to it's original position, screw the case back together, and power on the computer. Your BIOS password should be removed. Keep in mind that this will also restore all BIOS settings to factory defaults.
Sep 20, 2013 | Lenovo G570
Toshiba PSLC8U-03701Q factory restore
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to
hope this helps you
Mar 18, 2012 | Toshiba Satellite L305D Notebook
I have a Toshiba Satellite 1805-s207 I need to remove the password and rest it on the Bios so i can do a clean install
There are multiple methods to remove a BIOS password. Click here to read an article which goes over a simple method to do so. CMOS battery removal bypass password
If you wish to perform a clean install, you can insert your Windows and Linux disk and change the boot order to boot to the media device holding the new operating system. In some model of computers they have recovery partitions that are used to restore laptops to factory defaults.
I would first suggest you remove the virus. It should be simple. Boot your computer into SAFE MODE. To do this, while the computer is first powering on keep pressing the F8 key until you get a menu. Choose Safe Mode. In Safe mode go to Start > All Programs or Programs > Accessories/System Tools > System Restore. Choose a restore point to when the computer was unaffected. This should help.
If you have questions please let me know.
Regards,
G33k
Dec 02, 2011 | Toshiba Satellite 1805-S207 Notebook
How do i reset my toshiba satellite back to factory settings
Hi
Press Alt key and F10 key continuesly as it boots up.
If not, then you need run your computer in Safe -mode set up by pressing F8 key (ADVANCE BOOTING OPTIONS). In the advanced options, under system restore there should be the option to restore the factory default installation. Back up your files as i will delete everything. Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help. Regards and thank you for using Fixya !
May 14, 2011 | Toshiba Satellite L505-S5966 Notebook
Toshiba satellite L300 black screen. Tried the 0 key and it only goes 1/3. thinking booing/registry corrupt. No recovery disk or software came with my laptop. O/S is Vista I have data and photos that...
Yes everything will be wiped out, once you do the recovery. It will reinstall the factory settings.
You may try this first; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, then try to boot from safemode. Tap F8 upon booting up to enter the advance boot option. Select safe mode, save your files once loaded in safe mode. You may first try the system restore from , go to start/all programs/accessories/system tools/system restore, select the previous date the laptop was working fine. If this will not work then the last resolution is the recovery.
Hope this helps.
Mar 22, 2011 | Toshiba Satellite Pro L300 Notebook
SATELLITE U305-S7448. Vista is badly corrupted and I have no factory restore disk. How can I obtain a factory restore disk? Boot up restore option doesn't work. There appears to be no restore...
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
Hope this helps don't forget to vote
Feb 15, 2011 | Toshiba Computers & Internet
How do you restore to factory setting
Press F2 during the boot to get to Cmos. Once in Cmos go to the Exit tab and locate the line for Set to Factory Defaults and chose it. Your system will be back to the factory spec after a new boot. Some systems have diffrent Function keys to get into Cmos so watch the boot screen for the correct key to press. Most are the F2. Good luck!
Jun 06, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite A135-s4677 default passcodes
Hello, There is 3 things you can do.
1st the most easy thing to do if you have nothing important on it then do a complete system restore. by selecting the relevent key f10 f11. OR you could try pressing F8 before wndows starts to boot then from the new menu select recovery option from that menu the follow the on screen options
2nd if it can be done as an option in the restore menu then do a partial restore to a previous point that might remove the password.
3rd use another computer to download a password removal tool this uses the startup boot via a bootable dvd/cd it then uses its built in program to access the Microsoft password system then to either remove or change the password.
However if it is the bios you will need to short the cmos by taking it apart removing the battery or using the jumper to clear it. this WILL void any warranty though.
Sep 25, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A105 Notebook Logo
352 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
