I bought a blackberry curve and a jabra vbt2050 bluetooth. The bluetooth paired and connected twice. Then I got a message that the bluetooth could not connect. I deleted it from my phone so I could try to re-pair the bluetooth. Now the bluetooth will not display a constant bluelight. It flashes a few times and then turns off. I have been charging it for days, but it doesn't seem to change anything. I cannot pair the device now.
-   vbt2050 worked fine with my envy, now can't get it to connect...keeps saying that the device is out of range or turned off when it is on and sitting right next to the phone.
have taken it out and re-paired...device info says that it is disconnected and I don't know how to connect it.
when I hit the option button that says turn on I get an icon that says Plese wait...
any help would be appreciated.-   fi313
May 03, 2009
-   i wont pair with my ps3
-   theboyjes232
Apr 19, 2009
-   i just need to know how to put in pairing mode-   Guest
Mar 18, 2009
-   I was able to get my phone to find the bluetooth but the pin of 0000 does not work. Says it is invalid -   errin24
Jan 31, 2009
-   I've had so many issues with my bluetooth VBT2050 picking up signal with my evV phone. Verizon even sent me new bluetooth model and the same think was happening. I re-activated my razor phone as a last attempt, and it pairs just fine. In my case, it's not the headset that was having the issues. -   Guest
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
I hope this might help some of you, but the instructions for my bluetooth (jabra vbt2050) said the PIN is 0000 (4 zeros) Try to pair you VBT2050 this way.... it should work. Good luck.
I too have a Blackberry (the Pearl) and can't get the VBT2050 to pair. The "V" in VBT I think stands for "Verizon". I have AT&T service. I thought bluetooth was universal... is it impossible to get this particular device to connect because my carrier is AT&T?
Comment by Guest, posted on Jan 07, 2009
I can't seem to get my VBT2050 to pair even after typing in 0000. My phone finds my printer, and laptop though.
