Question about Bose Acoustimass 15 System
Have a Bose Acoustimass 15, Would seem the fuse has blown, all other speakers work. Have removed two screws and the two knobs. Found the slider mechanism, and moved it facing up towards me, issue is still can not slide the cover off, Does it go towards the inputs, or up? Is it worth it since the fuse I guess is soldered?
  • 51 Answers
Of course it's worth it - just unsolder the old fuse and solder a new one in. But first make sure the fuse is really blown. Buy a cheap $10 ohmmeter and check it - a good fuse will make the meter respond, or make the ohmmeter beep. Note that a blown fuse might still make the ohmmeter respond, since other circuits connected to the fuse will affect the reading. So look for zero ohms. If you get like 5 or 10 ohms or more, the fuse is blown. It may not be the fuse, but this is the first step to find out. Best way to check fuses is to unsolder and lift one end, so that you're only reading the fuse.
Posted on Dec 27, 2008
Replace fuse bass module
If there are no obvious screws holding the back in place, then the only way to have access is to remove the grill, remove the speaker and go in from that end to perform the needed repair of the connector. You can remove the wires from the speaker so it does not get in the way as you use the speaker opening for access. good luck.
Sep 06, 2017 | Bose Acoustimass 15 System
Bose acoustimass 15 no sound out of left and right speaker
The left and right front speakers may have been blown
Jan 28, 2013 | Bose Acoustimass 15 System
I have the Bose ac 15 system and i plugged it in straight into 220 when its 110. now obviously it doesnt turn on, what do u think happend? blown fuse? Thank you very much.
can be chance for fuse blowing. also check is there is any MOV ( used for over voltage surge protection) chance to become shorted. if MOV is there, insert fuse only after replacing MOV.
Dec 22, 2010 | Bose Acoustimass 15 System
Dead Bose acoustimass bass module
Even i have the same problem.bose does not providing a single sub-woofer
Feb 20, 2010 | Bose Acoustimass 15 System
No sound from speakers ( lifestyle 20 )
remove the screws that hold the amplifier block to the speaker.the fuses are in the amplifier inside
Jun 14, 2009 | Bose Lifestyle 20 System
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
I lost sound on one side of bose stereo system., Seems its the power ouput on the right side speaker, i changed speakers and the right one works when plugged into the left output. How do I open the bose...
first lets check
no need to open any thing
1) just trace the wire of working channel and plug out that and connect to opposite side of that channel
for example: if front left is not working, remove pin of front right and plug it into front left
after that listen the sound if front left is working then no need to open amplifier just check the wires of satellite speaker which is not working
how to check broken wire:
1) just observe your speaker nearly if you found any screw holes open it, if u can not find any screw holes remove front net which is fitted by press lock or any stepped groove, you can remove that and if you are removing front net you have to open speaker from casing then after you can find speaker's wire shouldered or bolted to it just check wire and go on after that u'll be sure that weather your speaker is failed or wire!!!
(don't forget to rate)
Jan 04, 2009 | Bose Acoustimass 15 System
Bose Acoustimass 15 System no power
same problem, i found the transformer looks like the wax or glue melted down on the cir board . . . not sure if that the problem but has anybody seeing the same ?
Sep 20, 2008 | Bose Acoustimass 15 System
Bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Jun 24, 2008 | Bose Acoustimass 15 System
Bose Acoustimass 15 System Logo
750 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
