Question about Texas Instruments TI-Nspire Graphic Calculator
Loading Screen Freeze
When I use either keypad for the ti-nspire it goes through the loading phase until the loading bar is completely filled. At this point the screen freezes and is not responsive to anything. I can take the keypad out and hit the reset button on the back but the message on the screen stays the same. i tried changing the batteries and that doesnt work. suggestions?
  • Anonymous Apr 01, 2014
    My screen brightness is really dim but i dont know why. I think it might be because of my battery. Any suggestions?
  • 4 Answers
  1. Remove the keypad (for TI-Nspire) or the battery door (forTI-Nspire CAS) and remove at least 1 battery from each column ofbatteries. After 2-5 seconds, reinsert the batteries and turn the uniton. This will cause the unit to reboot the operating system.
  2. Holddown [Home] [Enter] [P], and while holding these keys, press [On]. Thedevice will boot up as in the previous reset, but will display a menuwith the following options. Please try options 2, 3, and 4 in thatorder.
    1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts. 2. Delete Operating System – The operating system will be deleted without deleting any documents. 3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS. 4. Complete Format – This will delete the OS and all documents for a total erase of memory.
    Note: TI-Nspire family model options 2 and 4 above require that the OS be reinstalled. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
Posted on Jan 30, 2009
My TI NSPIRE CX CAS is stuck at the loading screen - it keeps loading and then going back and repeating (only when plugged in). I have tried resetting it whilst holding down EE, doc and enter. When I do...
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and
the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
• While holding these keys press [on].
Please Note: For TI-Nspire Family handheld units that
contain rechargeable batteries you can alternatively hold the above
keys while pressing the [reset] button on the back of the handheld rather than
removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu
with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit
restarts.
• 2: Delete Operating System - The operating system will be deleted
without deleting any documents on the system.
• 3: Delete Document Folder
Contents - This will delete the user's documents, but will not delete the OS.
Selecting this option is the same as using the RESET hole on the back of the
unit.
• 4: Complete Format - This will delete the OS and all documents for a
total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled.
Oct 09, 2013 | Texas Instruments TI-Nspire CX CAS...
My ti nspire cx cas is totally stuck at the loading screen , it keeps reloading and reloading with a sign at the left corner at the bottom that say's that my battery is empty ? what should i do ?
I have a doubt, when I choose to completely format the calculator it will clear your operating system, files saved on it, but the product key (ID protuto) will be deleted too?32d3cd84-9b87-4f5d-abfe-aa04ca86df4c.jpg
Dec 18, 2012 | Texas Instruments TI-Nspire CX CAS...
Ti-nspire with 84 keypad problems
It seems to me that you get the loading bar when you switch keypads. I just switched keypads, and when I reinserted the TI84 Plus keypad back again I found my last TI84 Plus screen contents still displayed.
As to the RAM cleared message, it probably is related to the batteries being depleted.
To verify battery charge level, you may use TI connect.
Mar 31, 2012 | Texas Instruments TI-Nspire Graphic...
I installed the new 2.1 OS to my TI-nspire and when it restarts it always freezes at the "loading os" screen with the bar completely filled all the way.
First of all you will need to erase your calculator by holding Home(house key)+enter+P and than the on button. Make sure the on button is the last button you press. Then, select option 2 to erase your operating system. Then, you need to obtain the operating system 2.0 for the calculator. Download and install that onto the calculator. It should install operating system 2.0. Once you do that, download and install operating system 2.1. This will allows you to upgrade your calculator to the latest version and get past the full bar loading screen. Let me know if you need anymore help.
Aug 19, 2010 | Texas Instruments TI-Nspire Graphic...
I have issues turning on my TI-Nspire using TI-84 Plus SE keypad
i would say use the normal key pad or send it in to T.I to fix.
Mar 12, 2010 | Texas Instruments TI-Nspire Graphic...
TI-Nspire 84 Plus keypad problem
Remove the TI84 Keyboard, insert the TI-Nspire keyboard and try to reset the calculator with a starightened paper clip.Calculator has a reset button on the back.
Jan 23, 2010 | Texas Instruments TI-Nspire Graphic...
Frozen Calculator
I am glad it worked for you but TI advises against removing the keypad while calculator is on. There is a possible loss of information.
Aug 10, 2009 | Texas Instruments TI-Nspire Graphic...
I have a TI-nspire CAS calculator. When it is switched on it begins loading and then comes up with System Error. What do I do?
You should ( a suggestion) reset the OS by pressing the button on the back of the unit.
If that does not work, you may consider reinstalling the OS. The procedure as described in the TI Knowledge Base is as follows.
What steps are required to reinstall the TI-Nspire family operating system?
To reload the device’s OS using a computer with TI-Nspire Computer Link:
• Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable.
• Open the TI-Nspire Computer Link software. The select device dialog should appear, and detect the device.
• Either drag the OS file (available in the ‘downloads’ area at education.ti.com) onto the TI-Nspire File Browser portion of the window, or click Tools -> Install OS.
To reload the device’s OS using another TI-Nspire or TI-Nspire CAS device:
• Connect the two devices using the USB Mini A to Mini B cable. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
• On the sending unit, access the document chooser by pressing [Home] [7]. Once in the document chooser, press [Menu] and choose 9:Send OS…
NOTE: Users can only send an OS to a unit of the same model. Users cannot send an OS from a TI-Nspire to a TI-Nspire CAS.
Please see the TI-Nspire guidebooks for additional information.
Hope that helps.
May 08, 2009 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-Nspire Graphic Calculator Logo
607 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
