Question about Sony TCM-200DV Handheld Cassette Voice Recorder
Making a cassette-recorder capable of overdubbing
I have a sony TCM 200dv tape recorder and i heard there is a piece you can remove to make it so that you can record multiple tracks over eachother without losing each previous one (so basically it can overdub) anyone know about this?
5 Suggested Answers
pomonabill22
  • 7 Answers
SOURCE: tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Posted on Aug 11, 2007
rockfixya
  • 679 Answers
SOURCE: I need a manual in English Sony TCM-150 Cassette Recorder
i find user manual for your recorder, download manual from the link>>
http://www.usersmanualguide.com/sony/voice_recorders/tcm-150
please do not forget to rate this solution.
Thanks for using FixYa.
Posted on Jan 28, 2009
boatadjare
  • 195 Answers
SOURCE: How do you record over beat in Sound Forge Audio Studio 10?
log on to www.sonycreativesoftware.com/news details and guidelines...
Posted on Jul 16, 2010
Ironfist109
  • 3018 Answers
SOURCE: sorry for my terrible english
  • So if I understand you right, and I think I do. You are putting the looping on so you can record your own tract but for some reason the amount of time you think you have recorded is not being reflected in listening to the playback correct?
  • When you push play then the beat will begin to play. It will continue to play until you stop it. Now while the beat is playing you want to hit "record" to record anything you want to have recorded. If you hit the record button again then this will pause what you are recording BUT you will continue to hear the loop. This allows you to choose different parts of the loop to lay a chop down on. So in other words if you press play (this allows the selected loop to being) then you press record to record everything. If you press record again while the loop is playing this will stop ALL recording but you will still hear the selected loop playing. You have to press record again to continue recording.
  • Also remember that if you have somehow reached 24 minutes of recording then you have to remove it to make room for more recording. You do this by hitting the "undu" button.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Aug 03, 2011
Recorder button does not go down. . Is there anyone who knows how to fix this problem
There is an interlock that prevents accidental recording. You may have to press PLAY and RECORD at the same time.
Jan 01, 2015 | Sony Tcm939 Table-top Tape Cassette...
How to erase a recording on a Sony TCM-150 cassette recorder?
Just press the record button. Also make sure the cassette is not write protected.
Sep 07, 2014 | Sony Tcm-150 Standard Cassette Voice...
Transcriber repairs
They're cheap. Buy another one.
Feb 03, 2014 | Sony TCM-150 Handheld Cassette Voice...
Vcr ejects tape when i try to record.
is the erase protection tab removed from the cassette?
if yes there is a square hole on the back of the tape visible when you insert it.
put a piece of sticky tape over this hole and make shure it does not come loose.
it should record fine now when you insert it again.
Aug 30, 2010 | Sony SLV-N51 VHS VCR
Record button is stuck and cannot be pushed down.
Make sure the tape is not protected or broken tap on bottom of tape
Dec 08, 2009 | Sony Pressman TCM-929 Desktop Cassette...
How do I erase a tape that has already been used?
Try press Rewind & Record and if does not erase I recommend to get a tape eraser from tvps
Mar 31, 2009 | Sony Pressman TCM-929 Desktop Cassette...
Jan 28, 2009 | Sony TCM-150 Handheld Cassette Voice...
The screen that says reinsert the cassette.
Tht means the recording protector tab of the tape is on, check the tape, most or f the time there will be a plastic piece tht can be broken off if u need to prevent any thing from recording on it, try covering the hole with a piece of adhesive tape and try recording
Nov 04, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony TCM-200DV Handheld Cassette Voice Recorder Logo
155 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
