Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
1989 Javelin FS396 lisp to the left constanly
How do i check if outboard is square to the boat? When starting out the boat really leans to the port side and stays that way until i reach around 40mph
  • 3 Answers
Does the steering pull to one side while coming up to speed.
Have you adjusted the trim tabs on the motor?
they help to counteract the prop torque.
the motor will naturally have a torque to one side
because of the prop rotation.
Posted on Jan 21, 2009
What size gas line for '77 johnson javelin 85hp outboard ?
There are considerations:
1. How long of a hose?
2. Fittings on the tank and motor.
Since you did not post that info, I cannot assist you further
Mar 18, 2017 | Johnson Boating
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Apr 13, 2016 | Motorcycles
Outboard will not start tried changing spark plugs,fuel filte,r clean fuel
Top 25 Reasons Your Boat's Engine Won't Start ' Boating ...
BoatingAug 10, 2012 - A list of things to check for outboards, inboards and sterndrives. ... Top 25 Reasons Your Boat's Engine Wont Start. Even the mood created by ...
Basic Trouble Shooting When Your Outboard Won't Start ...
? 2:18
Feb 23, 2014 - Uploaded by
... on basic troubleshooting when your boats outboard won't start will help you get ... Outboard won't crank or turn over, electricstart not working ..
Nov 23, 2015 | Boating
How to adjustment jets on a suzuki 115 hp outboard 1989
I am not familiar with the Suzuki brand but short of small motors (under 25 hp) most if not all motors by 1989 are fixed jet and not adjustable. If fuel is the problem, cleaning it the answer.
Jul 07, 2014 | Light Outboard Motor Boat Bass Fishing...
It's A 2 Stroke Outboard?
Looking At The Engine On Port Side Its The Square Piece With Two Pipes On It ONe Comes From Fuel Filter The Other Goes To The Carbs.
Mar 15, 2013 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
1989 galaxie boat. inboard/outboard 4.3l stiff steering
The first thing I would do is disconnect the steering at the transom. You want to find out if the problem is in the helm(steering wheel) or in the inboard/outboard pivots.
When you turn the wheel after the disconnect, it should not be hard. There is a set screw in the steering assembly either above or below the dash. There should be enough tension so the boat does not wander but not enough to be terrible to steer.
Next go to the outdrive. Without the steering connected, the outdrive should move with minimum resisitance in either direction. There are pivot points on top and bottom that should have marine grease at the start of each season.
You have a 21 year old boat. The driveshaft in the Inboard/Outboard should be greased every 2 to 3 seasons and the watertight bellows can be inspected at that time.
Now if the steering is even worse under power, you need to adjust the fin that drops down behind the prop. This part controls Torque steer so the outdrive is not trying to turn on you and wants to stay straight. If you do not have a problem leave it alone.
You can get an estimate for the driveshaft service and greasing U-joints and inspecting the bellows. They should grease the pivot points then too. I am told its about a 2 hour job. In my area its 60-70 an hour.
Apr 12, 2010 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
195 people viewed this question
Top Light Boating Experts
ray gallant
Are you a Light Boating Expert? Answer questions, earn points and help others
