Question about Foxconn NF4K8MC-EKRS Motherboard
Computer will not POST and stops at the hexadecimal display code "C0" its a Foxconn motherboard
  • 45 Answers
Reseat RAM, CMOS re-boot.
Posted on Dec 21, 2008
What does error code 155 mean
This is not error code. If a fault occurs on your device it will be displayed in hexadecimal code for example:
Newer models: i10, i20, i30 ....... i90, iA0,.............iF0
Older models: A0, A1 ........ A9, AA, Ab,............. Af
or C0, C1 ........ C9, CA, Cb,........... Cf
Because that I believe that the digit number "155" that you see on the display means the duration time (minutes) of selected program. Also see in user manual how to cancel selected program and choose new one.
Dado
Nov 04, 2014 | AEG 23 in. Favorit 50750Vi Built-in...
POST Codes?
heat sink maybe not fast enought
Dec 10, 2013 | Foxconn 741m01c-gx-6l - Socket 462...
Foxconn POST Codes
http://www.experts-exchange.com/Hardware/Misc/Q_21841847.html
Long continuous loud beeping sound coming from the foxconn a7vmx-s motherboard. Please help
These are called Beep Codes. The kind of beep indicates that the motherboard cannot post, and gives you some idea of what is wrong. These codes should be located in the booklet that came with your motherboard or the computer. You can also try the computer manufacturers website, hopefully they posted a manual for your computer.
Sep 19, 2013 | Foxconn A7VMX-S Am2 Ddr2 Motherboard
Need Foxconn SuperUpdate application for motherboard bios update please.
BIOS DRIVERS
Click the link above for BIOS drivers and updates you need for your computer set.
Enjoy.
Should you have any questions feel free to update tihs post.
Jun 03, 2010 | Foxconn 6627MA-RS2H Motherboard
EliteGroup ECS AMD690GM-M2
get a debug card, put in the pci slot, put the processor, memory, hdd keyb, mouse on the place, double check it..turn on the power , read the last post code that display...watch for the blink of the 3 keyb lamp during power on...if there is no blink..then your o/b vga not initialized by the bios and (maybe) reading the other exp slot.
if there is a blink then check your monitor and cabling..record the last post code that display on the debug card (POST code display card), shutdown then remove all your device except for processor,ram,debug card , vga(if any external)...turn on the power again..did the post code is different or its the same with the last time?
shutdown,remove the ram, and vga (if any ext vga)..power up again (with only debug card and proc) did the code display the same or no ?
remove the proc and still with the debug card inserted in the slot..power up...what in the display?same?
you should be able to diagnose that..may be the proc (code 00 C0 C1 C2 ), may be the ram...maybe your o/b vga was dead..maybe your bios rom was still have bug (ECS ??=>does have a 2-3 years waranty..am i right?)
UDIN (indonesia)
Jun 13, 2008 | EliteGroup ECS AMD690GM-M2 Socket AM2...
IT USED TO RESTART ABRAPTLY BUT NOW NO DISPLAY
Hello Arua
I would suggest you get your hands on a 4 digit post card to diagnose the problem
heres one
http://cgi.ebay.com/PC-DIAGNOSTIC-CARD-4-Digit-PCI-ISA-POST-Code-Analyser-N_W0QQitemZ130196339829QQihZ003QQcategoryZ162QQcmdZViewItemQQ_trksidZp1742.m153.l1262
  • Determine defects by difference sounds coding with build-in speaker.
  • It can diagnosis the motherboard signal which show the problem of CPU, Memory, video card, etc.
  • The POST code display is made up of a dual, dot matrix hexadecimal read-out that display's Power On Self Test (POST) status codes
  • Support the power source working indicator -- +5V,+12V,+3.3V and 12V(When indicator LED is on to indicate its respective power is fine, otherwise to indicate its respective power is failure.)
  • Fully compatible with any kind motherboards which has the PCI and ISA bus slot.
  • If this solution was any help at all please press accept or ask more questions with the other button.And if you need anything else let me know, you can ask me 24/7 by clicking
    on the ask me button, I will ansver in most cases within 24hours.
    Thanks and good luck!
    May 05, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    Install motherboard drivers for the first time
    did u format your hard drive with new mobo ? resisnatll it all then defult bios rechesk all settings in there
    Jan 19, 2008 | Foxconn (945G7MA-8KS2) Motherboard
    Foxconn Motherboards Led Boot display
    Without more detailed information, I really can't help you decipher that code... Since you don't know which specific Foxconn motherboard you're working with, it might be best if you contact Alienware Customer Support for detailed information:
    http://support.alienware.com/Support_Pages/Support_Area.aspx
    Good luck; let us know what you learn...
    Nov 21, 2007 | Foxconn (865G7MC-ES) Motherboard
    Foxconn NF4K8MC-EKRS Motherboard Logo
    52 people viewed this question
    Top Foxconn Computers & Internet Experts
    Alun Cox
    Rommel Balcita
    David
    David
    Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
