Question about U.S. Robotics MAXg USR5461 (738168036790) Wireless Router
Setup Wireless Router to Westell 6100 modem
I have 2 computers, but only one with internet. How can I setup the Wireless Max g router (by U.S. robotics) with my Westell 6100 dsl modem?
  • 55 Answers
Your Wireless router should have come with a CD. Insert the CD into your computer and follow it step by step. If it did not come with it here is a basic wiring setup.
From wall jack to Westell modem, From modem to uplink port on Max G router.
Reboot Westell modem. T
Everything should auto-configure unless you need a username and password for your DLS. If so you will need to program this into your router.
Posted on Dec 21, 2008
I have another computer i want to install in the up i need another dsl router to connect to it????.
If you have a Westell 6100, it's just a modem meant to connect a single computer to the Internet. It has the jack where you plug in the cord to your DSL phone line, and an Ethernet jack so you can plug in your computer. You can't have more than one of these connected to the phone line because of address conflicts that would result.
What you need is a wireless router so your Internet connection can be shared by several computers. Most service providers are installing Westell models that combine the modem and a 4-port wired/wireless router for new customers now. Since you have the modem only, you'll need to supply the router. The wireless function lets you use the upstairs computer without having to run a network cable to connect it. That's much cleaner and simpler. There will be four connectors on the back of the router for wired computers or other things (such as a network printer) you might want to connect. You still have only one connection to your DSL line, but now you can hook up several computers at once.
There are several companies making wireless routers and they all do pretty much the same thing. Netgear, Linksys and D-Link are the most common, and you can buy a wireless router at almost any retailer that sells computers. You can also find them online from companies like TigerDirect or Newegg. Other than staying with one of the major brands (it's easier to find support for those if you need it), there's not much to recommend one kind over another.
It's pretty easy to install a wireless router and set up your wireless network. They all come with a CD containing setup software that will guide you through the process. You'll have that upstairs machine on line in no time.
Dec 05, 2010 | Westell Wirespeed LiteLine 6100...
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
Switching from a verizon 6100 dsl modem to a 327w versalink
make sure that your old setup not still on go to connect to from the start and right click on the connection and see the one that you are using is present
Nov 08, 2009 | Westell Wirespeed VersaLink...
I have a westell 6100 and I have a linksys wireless-g 2.4 ghz broadband router. Not sure how to hook the router to the 6100
just set it up as a passive style and do not let it log on to your isp it should default to this setting if you plug it up and do not run the setup software
Apr 12, 2009 | Westell Wirespeed LiteLine 6100...
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
Apr 10, 2009 | Westell Wirespeed LiteLine 6110 Modem
Need to redo wireless setup betw linksys & westell
You will need to assign a different ip address to the Westell modem - I am assuming that both the router & modem are using the same ip address If that is the case, then assign to the modem.
Mar 15, 2009 | Linksys Wireless-G WRT54G Router
Can not setup modem:Westell 6100 to router:Linksys WRT54G
i think the best way is to describe to you the physical setup first. so you have a computer, a modem, and a router. the setup should be like this: from the walljack, the phonecable is connected to the 6100, make sure there are no micro filters connected between the walljack and the phone line because it will not allow you to connect to the dsl. from the modem, the data/internet cable at the back of it, using an ethernet cable, should be connected to the router. and at the back of the router E1 to E4, another ethernet cable is connected there and the other end of the cable is to be connected to your computer. you are right in bridging the modem, the reason for that is because both the westell 6100 and router have GUI's or Graphical User Interfaces, in short, they each have their own virtual brain. you will not have a connection if both of them have this GUI thing, so you need to bridge your westell 6100, so that the only GUI active is the routers. to bridge the modem you may need assistance from tech support of your ISP provider. assuming that's done, light status in your 6100 should have a solid DSL light. for the router, it should have lights in WAN, WLAN if you want to connect wirelessly and E1 to E4, whichever ethernet port you're using for a wired connection. you have to access the GUI of the router to make sure you have a routable WAN IP Address. As for the IP address in your computer, it should be a type of ip address. this is the LAN IP Address. Basically you need to have routable WAN and LAN IP Addresses to be able to connect online. you will need to configure the GUI of your router to be able to do this. for that you may need assistance from tech support of the router or if you can follow the instructions in the manual, by all means do so. the most important thing in this setup is bridging the modem.
Dec 20, 2008 | Computers & Internet
Setup DIR-655 w/ Westell 6100 USB DSL Modem
First check if your computer can get on the modem with an Ethernet ( This is to find out if your router will work with your modem) If you cannot get on give your ISP a call to have them configure the modem for Ethernet connection. If you do get on then connect the router to the modem and your computer to the router. You can run the CD for the router or do the connection manually.
Jul 27, 2008 | D-Link Xtreme N DIR-655 Wireless Router
Get no connection useing 6100 modem connected to wireless B router
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be or depending what ISP youre connected to . For ATT broadband its / verizon broadband is  { onyour address bar : type in and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in or Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
May 21, 2008 | Westell Wirespeed LiteLine 6100...
Open Questions:
U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Logo
757 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
