Question about HP Photosmart C6180 All-In-One InkJet Printer
HP C6180 Unable to scan
I saw your advice but it did not work.
I posted my comments on the forum.
Any chance you have any other suggestion to fix the issue.
I am wondering whether it is a software or hardware problem (scanner lamp? power source? motor? PCB board? LED reading?...)
I would appreciate your expertise
thx
L
  • lindakhenry Jan 11, 2009
    Mac OS 10.6, Fails to initialize scanner.
hashir4u
  • 79 Answers
SOURCE: Can't scan from printer or computer
Close the Digital Imaging Monitor.
◄ Start or restart the services :
1. HP Cue Device Discovery.
2. HP Net Device Discovery.
3. HPQCS08.
◄ Run Digital Imaging Monitor.
◄ Wait for a Minute, if the configuration screen appears it is done else refresh the HP Cue Device Discovery
◄ Restart the Printer
◄ 99% chances of resolution and in the other cases a proper uninstall and reinstall is needed
If the issue still remains then :;
Added the files to the firewall exception list
C:\program files\HP\digital imaging\bin\hpiscnapp.exe (version 10 software )
•C:\program files\HP\digital imaging\bin\hpqscnvw.exe (other than version 10 software
•C:\program files\HP\digital imaging\bin\hpqste08.exe
•C:\windows\system32\hpzipm12.exe
•C:\windows\system32\hpzinw12.exe
•C:\program files\HP\digital imaging\bin\hpqtra08.exe
•C:\program files\HP\digital imaging\bin\hpqthb08.exe
i. 68: dhcp client
ii. 80: web server
iii. 137:UDP Port 137 netbios-ns (UDP)
iv. 139: netbios-Session (TCP),
v. 161: snmp. (UDP)
vi. 427: srvloc. (UDP)
vii. 5353: mDNS
viii. 9100: pcl/pjl print.
ix. 9101: debugging tcp recv/send
x. 9102: debugging tcp send
xi. 9103: debugging udp recv/send
xii. 9110: echo
xiii. 9220: generic gateway (scanning, pml).
xiv. 9290: scan.
xv. 9280: generic gateway
xvi. 2500: scan.
Posted on May 25, 2008
adonscott
  • 106 Answers
SOURCE: HP C6180 AIO Scanner Failure
hi,
The "Scanner Failure" usually refers to the hardware of the printer. try to do a reset.
Performing a semi-full reset of the All-in-One
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
If the issue still not resolve, please call HP 1-800-474-6836. Also check the warranty status of your printer.
thank you so much.
adonscott
Posted on Jul 26, 2008
sagarjd
  • 95 Answers
SOURCE: HP C6180 ''Unable to scan, copy or send a fax''
Check the following steps:
Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord
Try to check the result.
Regards,
Sagarjd
Posted on Nov 21, 2008
SOURCE: Officejet 7310: Scanner Failure
If you get a "Scanner failure" message then the problem is the motor itself. Notice how the motor works fine when the scanner is moving slowly, like copies or faxing with the original laid on the glass. HOWEVER, the scanner failure comes up when you use the automatic document feeder on top. Why? Because the scanner assembly has to move to the other side of the printer at high speed to get into position, and it's the high speed movement that triggers the error on the printer. The motor is expensive, part number Q3450-60003. Many other models use the same motor, maybe you could find one cheap somewhere and swap the motor?
Posted on Apr 06, 2009
bimbabampish
  • 14 Answers
SOURCE: HP psc 1350 missing scanner software
Have had this problem for long time. Tried many tricks without success and only managed to get the printer to work but not the scanner. Unfortunately only way out of this frustrating problem is to get the original scanning software on CD. The download file on HP support site (343.28MB) simply does not work! Anyone who would please post the CD software for download would help lots of people!
Posted on Mar 18, 2010
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
May 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
AM UNABLE TO SEND ANY FAX SINCE WE GOT THE MACHINE. ALWAYS "NO ANSWER" PRINT-OUT. NO PROBLEMS WITH COPYING AND SCANNING Need steps to send fax.
HP has a huge database available to help with such problems when getting started. It may take some time to find any given item but they are available from the company and in user forums.
Nov 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp C6180 Colors don't work
HP has an excellent online support site. Go here and look for solutions, and see this article.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
I need an HP LaserJet driver that is compatible with MAC OS X that will support HP LaserJet 1100
Can you post your solution on the same page as your problem and comments?
I found a solution but saw that you got it solved before I could post and this is what I found http://www.linuxfoundation.org/en/OpenPrinting/MacOSX/hpijs
I found it on the Linux OpenPrinting site but this package works with Mac OS X as well. It also works with more than 776 printers.
This is an HPIJS for Mac OS X and the page gives package details describing the drivers as well as installation instructions. I work with HP computers at my job but have not yet had a chance to try this out on the MAC operating systems.
I'm glad you fixed...what a feeling! LOL!
Mar 29, 2009 | HP LaserJet 1100 Printer
C6180 scan unable!! conection error reported
Get the right Driver's and will work fine than recalibrate the printer. .http://welcome.hp.com/country/us/en/support.html
Jan 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Wireless vs USB connection
This is a known issue and Hp has released a patch.
I think the patch file is 10862.exe. But downloading the newest version of the driver from HP's site may now fix it now too.
Here is the link for the HP driver site.
Aug 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
My Sony Vaio won't print using my printer HP C6180
Is the ink of your printer there?? Or finished. Check this n then try to print again
Jul 15, 2017 | HP Photosmart C6180 All-In-One InkJet...
Problem with c6180 when used with mac/leopard
Follow below instructions to scan more than one pages to a single document :
1. Open HP solution center.
Click Start - All programs - HP - HP Solution center.
2. Click Scan document - Click Accept.
Computer will ask "Would you like to scan another page?" Say Yes and scan the other side of the document by following onscreen steps.
Thanks
Dec 22, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
82 people viewed this question
Clive
Clive
