Question about JVC LT42P789 42 in. LCD TV
SETTING UP NEW JVC LCD TV
CAN'T GET PICTURE ON THE TV - HAVE THE CABLE OUT GOING INTO THE BACK OF THE TV? IS THERE AN INCORRECT SETTING?
  • Anonymous Jan 05, 2009
    I just can't understand what i've done wrong....
  • Anonymous Jan 28, 2009
    I also get a blank screen and a weak signal message on my JVC LCD TV.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
This TV has funny inputs. Video 4 and 5 have three inputs for the single buttons. I suggest using the input button on the side of the TV. Press the button, wait 3 second, then press again to go to the next input. This way you will cycle through all of your inputs.
If you are using HDMI it is likely that the cable box output is not setup.
Posted on Apr 29, 2009
  • Eleina Flaireheart Sep 15, 2010
    Just wondering..
    So, what should I do if I did tried all the inputs and still, nothing showed up? =\
    I've been trying to do what you said... (and as far as I could remember, that's how I used to do it to switch back on dish network) but for some reason, it's not working anymore. It kept saying "No program or Weak Signal".. please .. heeeelpp!!! =(((
JVC LT-50A330 TV. Sound but no picture. Screen is blue
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Apr 07, 2015 | JVC Televison & Video
HOW DO I FIX MY JVC PLASMA TV THAT DISPLAYS PICTURE AS NEGETIVE (SEPIA)
perhaps the cable to the decoder isn't fit tight. reconnect the cables to you're tv
Dec 06, 2014 | JVC LT-32X887 32 in. HDTV LCD Television
I have a 37" JVC LCD TV Model # T370HW02 and the left half of the picture if filled with vertical colored lines for approximately 30 minutes after the set is turned on then the picture clears up and s
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
Apr 11, 2017 | JVC Jlc37bc3000 37 Lcd Tv 1080p
CAfter the JVC model LT-42E910 is on for 10 minutes, the picture goes blank/black, but I have sound. I must turn off the tv and turn it back on every 5 minutes to get a picture. The tv is 4 days old.
It is a new tv.Take it back where u bought it and trade it in for another tv.This tv have those 2 LCD long inverter boards have problems.These 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the tv LCD screen to produced a picture.
Jul 07, 2011 | JVC LT-42E910 42" LCD TV
I have an HDMI hooked up from the back of my DVR box to my JVC, but the picture still doesnt look as clear as it should.. Would it have to do with how my settings are programmed? If so, how should my...
Check ur DVR box setting make sure is on HDMI cable setting mode or HD setting mode.The picture will be in HD setting and the picture will be coming into tv clearly.
Apr 21, 2011 | JVC LT42P789 42 in. LCD TV
No picture just sound thru dish network
There are a few reasons that this could happen. The main reason would be that the tv is on the incorrect channel or input. You will want to make sure that if you are at TV1, the channel is on 3 or 4, and an input if needed, such as VIDEO 1 or 2. If at TV2, the channel needs to be on 60 or 73. Cabling is another reason this could be. You want to make sure that if you are at TV1, all cables going from the receiver to the TV are connected on the back of the receiver at the green TV1 location. For TV2, the cable needs to be connected to the HOME DISTRIBUTION output on the back of the receiver.
Becki Barned
DISH Network Customer Service
Jun 01, 2010 | LG 52LG50 52 in. LCD HDTV
My HDMI connections aren't working. How do I
Tries unplug and replug the tv back about an hour.Let the tv reset itself back to factory setting.Now go in ur menu go to PICTURE.Go down the menu pick reset,that to reset all the funsctions in the Tuner board.This process should get all the HDMI Hub. working again,not than ur Tuner board have all the HDMI Hub. are shorted and dead.
Apr 27, 2010 | JVC LT46FN97 46 in TV
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
JVC LT42P789 42 in. LCD TV Logo
134 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
