Question about Dell 2300MP Multimedia Projector
Dell 2300 MP Projector: Wavy lines on screen
My projector recently started diaplaying wavy segments moving up the screen from the bottom to the top. The resolution seems to be getting poor as well.
Please, please help
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your description indicates that AC hum/component is superimposing on the video signal. This could be brought about by:
  • a faulty power supply capacitor;
  • loose shielding/grounding wire of the video cable;
  • electrical interference from nearby other electrical devices such as wireless phone, lamps with electronic ballast, lamp dimmer, or even the devices attached to the projector such as the DVD or computer or receiver.
Things you can try:
  • use a different outlet;
  • use a filtered power strip or an AVR similar to those used by desktop computer but with the power rating to the requirements of the projector;
  • change the signal cables;
  • inspect the internal circuitry of the projector with particular attention to the large capacitors of the power supply.
Another possibility worth mentioning is low AC voltage from the mains. Of course the best would be to perform voltage measurements and signal tracing with use of specialized equipment such as a scope while referencing a Service Manual.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 21, 2008
We are using a Dell 2300 projector. The Power
check that you have a signal going out of the monitor socket on your lalptop.
On Dell with projector connected and switched on, press the blue fn button bottom left usually, and while holding, press one marked CRT/LCD, (maybe f8) this will cycle to the following.
laptop only, laptop and monitor, monitor only, while holding Fn button press until you have desired outcome.
hope this helps.
Apr 12, 2010 | Dell 2300MP Multimedia Projector
Dell 2300 MP temp light flashes and projector turns off.
I am experiencing a similar problem with mine. It will cycle on and off without actually powering up fully and then after about the 4th or 5th time it will shut off completely and the lamp indicator light on top illuminates. i am reading in other blogs that this is a design flaw on this unit. let me know if you have found any fixes.
Jan 31, 2010 | Dell 2300MP Multimedia Projector
Wavy Video output from Marantz sr5600 Receiver
are you using component inputs s video rbg or hdmi?
Jan 31, 2009 | Marantz VP15S1 Television
Color wheel
Hi there
Simply locate your nearest Dell dealer and give them a call.
Apr 02, 2008 | Dell 2200MP Multimedia Projector
Dell 2300 projects verticle stripes accross the projector screen.
this is due to improper power supply or a loose connection inside. the symptoms are of power supply unit inside projector. check out the current and amperes inside the projector on board. sometime the current stable but the ampears are down.also check the switching transistors & filters inside.......
Feb 12, 2008 | Dell 2300MP Multimedia Projector
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
Dell 2300MP Multimedia Projector Logo
269 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
