Question about Motorola Mobility RAZR V3
Razr phone buttons won't work
Turns on and power on/off button works but when any other button is pushed the ring style menu comes on. I can't change the ring style but any button you push thats all that comes up Please help
  • Anonymous Dec 21, 2008
    unlocked motorola razr
    Brigadier General:
  • 7,752 Answers
Guest - try online at unlockitnow.com or mobile2mobile.net or take the phone to a mobile service center to have it unlock for a small fee.
skiel - the flexcable on the phone needs to be replaced to correct this issue
Posted on Dec 26, 2008
How to turn off text clicking
REDUCING KEYPAD VOLUME
STEP 1 Press the phone's menu key, located between the two soft keys on the top of its keypad.
STEP 2 Scroll to "Settings" and press the center key to select it.
STEP 3 Scroll to "Ring Styles," press the center key, scroll to the specific ring profile that you are using and press the center key to select it.
STEP 4 Scroll to "Key Volume," select it by pressing the center button, turn the volume all the way down and press the center button to lock your changes.
STEP 5 Press the soft key labeled "Exit" to exit the menu system.
STEP 6 Repeat this process for every ring profile in which you want the keypad not to make sound when you use it.
Mark
Motorola Support
May 09, 2014 | Motorola Mobility RAZR V3
My phones ring style is set to loud detail and volume is at the highest being 7,when I recieve a call it is silent?
Hi There,
As per my understanding you have set your ring style profile to loud and highest volume 7 but still ur phone phone rings on silent when someone calls..
Please change the Profile setting once again as mentioned below:
How to change call alerts and styles?
1.From the general menu, select "Settings" > "Ring Styles" > "Style Detail"
2.If you select one of the styles, ie. "Loud" you can then highlight by scrolling down on the wheel & select "loud detail" & press on the "change" button (top right corner key).
3.Here you will be prompted to change any feature available to the "loud" style: volume, ringtone, alerts, voice mail, text messaging sounds, reminders beeps etc etc. All you need to do is to select the feature you need to change with the directional wheel and press the "change" button for each.
If you think my solution helped u to resolve ur issue please do vote for me..
Thanks
Enjoy!!!
Oct 28, 2010 | Motorola Mobility RAZR V3
Can't turn off silent
the problem has a solution.There are two way to deactivate the silent mode on the phone:
Through the Menu,
or
Through short cut.
Go to through the menu, click on the menu button, you will see the settings of the phone. Click the setting button and scroll to the second option on the menu which is ring styles, click to open option one which is the style.
When you click the style option, you will see all the style options available in there. Then you can now select the one you want.
If you want to go through the short cut option, just hold down the harsh button ( # ) it will automatically deactivate the silent option.
Have a nice day.
Mar 17, 2010 | Motorola Mobility RAZR V3
Phone does not ring when call comes in on my Motarola Razrv3 cell phone. It vibrates but no ring. The ring volume is set on 7.
1st make sure that your phone speaker is not malfunction, to do this just play any ring tone from your phone to check whether there is a sound come out from the phone speaker.
If there is no problem to hear sound from phone then have to check the phone setting, to do this just PRESS and HOLD the button #, a shortcut to toggle between RING mode and VIBRATE mode. Or goto Setting>Audio>Style Detail, and change the alert type such as sound or music. Make sure u are not in the Silent style mode.
YBC (/\)
Oct 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
My razr does not ring when someone is calling
volume may be turned off or down or it is set on silent. go to settings, go to ring styles, select style and edit/add. scroll down to the ringer of choice and hit select. hopefully that will work. also try the volume on the side of phone. by pressing top left button, you can change ring styles that way.also controls volume.
Jun 27, 2008 | Motorola Audio Players & Recorders
Changing Ring Style
scroll down and it takes you straight to the ring styles and u can pick it straight from there x
May 20, 2008 | LG Shine KE970 Cellular Phone
Ringing styles problem sir,,
try resetting your phone to its factory settings...
Oct 16, 2007 | Motorola Mobility RAZR V3
Can't turn off annoying side key sounds
Did you try resetting everything to factory settings?
Aug 31, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Ring volume changing on its own.
Sounds to me like you have a stuck key somewhere on your phone. Was it dropped? Or maybe you hit it too hard. Look closely at the buttons on the side of the screen . you know, the ones that normally change your volume when it's open. One of those is malfunctioning in the down or closed position.
Nov 15, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
