Question about Philips Magnavox 51MP392H Rear Projection Television
Philips Model # 30PW850H37A Won't turn on
My 5 year old flat screen HGTV will no tturn on. When I press the power button it make a noise like it will poer up; however, after a few seconds, the center of the five lights on the front panel changes from green and starts blinking red.
  • Philips Master
  • 5,568 Answers
Likely power supply failure. This could be on a separate board that can be removed and repaired or replaced. Look for a smaller board with larger components that look like transformers and accepts the incoming AC line.
Posted on Dec 21, 2008
How do I tell which Philips flat screen I have
Well, personally I would say it is not worth fixing. The typical life span on flat panel TV's is about 5 to 7 years. Your set is close to the end of it's life cycle. Secondly, most experts recommend replacing your set if the cost of repair exceeds half of the cost to replace the set. By the time you pay the diagnosis fee, part cost, and labor cost, I think you will see what I'm talking about.
Sep 22, 2012 | Philips Televison & Video
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
Aug 20, 2012 | Magnavox 37MF437B37 37 in TV
Dvd "wrong region" on philips
How to break region for Philips PD9000D/37
1. Turn on player.
2. Open disc tray.
3. Wait till 'Open' appears on screen
4. Type 9 6 5 3
5. Press up or down button to reach REGION option
6. Press OK button
7. Scroll UP/Down to TEST0 , press OK
8. Press setup again to exit
May 08, 2011 | Televison & Video
How can I reset my Philips 37 in flat screen TV back to the factory settings?
You haven't mentioned the model no. of your TV. Nonetheless, the reset procedure for the model nos. 42PFL7409/98 / 42PFL7409S/98 goes like this:
1- Press Home,
2- Select [Setup] > [Installation] > [Factory
settings],
3- Press play to enter the [Factory settings]
menu
[Reset] is highlighted,
4- Press OK to reset to default settings.
5- Press Home to exit.
The reset procedure may differ for other model nos.
Furthermore, Press the "Menu" button to access the menu, and select "TV Settings" and then "Picture" to bring up the picture settings. Adjust the color, brightness, sharpness and other settings if the picture seems off. Select "Dynamic Contrast" to have the contrast adjust to screen changes and "Digital Noise Reduction" to cut down on outside interference and reduce noise in the signal. On the "Installation" menu, select "Reset AV Settings" to have the settings reset to their factory defaults.
I hope the above helps.
Good luck.
Jan 11, 2011 | Philips Televison & Video
My 5 year old Phillips flat screen HGTV will not turn on. When I press the power button it make a noise like it will power up; however, after a few seconds, the center of the five lights on the front panel...
I have no idea about where to get repairs as I don't live there but it sounds like you have a bad power board and it could be repaired yourself if you took the back off and got the part number off the board and ordered a new one. Please be a little careful when removing your board as if its been plugged in recently the capacitor on the hot side of the board can hold over 100 volts for awhile.
Nov 26, 2017 | Philips Magnavox 51MP392H Rear Projection...
Laptop wont turn on philips freevents x51
The most likely problem is that your Hard Drive has Died.
If you can readily access another Laptop HDD, try it and see.
Other than that, I'd say the Motherboard has decieded to give up the Ghost.
Just Remember, A Laptops life expectancy is 3 years, after that you are treading on thin ice keeping Important Documents on it.
Nov 27, 2008 | Computers & Internet
Philips Magnavox 51MP392H Rear Projection Television Logo
253 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
