Question about Car Audio & Video
On the back of my 10in subwoofer it has 2 seperate negatives and two seperate positves how do i wire this speacker to my amp on one channel.
This is known as dual voice coil, you will run a "jumper wire" from one negative to the other and the same with the positives, one of the connection points will have two prongs to connect to, when one of them is occupied with the "jumper wires", use the other connections to run wires from the sub to the amp and that should take care of the problem
Posted on Dec 21, 2008
How should i hook up a visonik class D vxd709 to my dual voice coil 12" Treo subwoofer?
if your amp is a monoblock 2 ohm stable amp wire the coils positive to positive and negative to negative into a single channel that will create a 2 ohm load turn your amp down and adjust by ear till it sounds good if your amp is a 2 channel amp 4 ohm per channel wire each coil one per channel turn amp down and adjust by ear till sounds good hope i was helpful
Feb 17, 2013 | Car Audio & Video
Tip
Solo x two amp usage
you can run two amps on the solo x. one for each coil. positve and negative from one voice coil. positve and negative for the other voice coil. two amps one sub.
on Feb 12, 2008 | Kicker 12" Solo X Subwoofer S12X - 5000...
I have 4 wires what do they do I no to of thim will go to my Kicier ame I Ddont no were the other to go
OK, I am assuming that you have 4 wires coming from the subwoofer itself. Your subwoofer has dual voice coils, this means there are two positives and two negatives. Look closely at the posts on the subwoofer and you can tell. These wires will go to your amp, all four of them. Here's the tricky part. You need to know if your amp is a monoblock (single channel) or two channel amp. Also, what ohms is it stable at (4, 2, or 1). If you have a monoblock stable at one ohm, take both positives from the sub and put to the positive of speaker output on the amp. Then put both negatives from the sub to the negative speaker output of the amp. If your sub is dual 4 ohm voice coils, this will give you a 2 ohm load. If you have a dual 2 ohm voice coil sub, this will give you a 1 ohm load. If you amp is 2 channel, just hook one set of positive and negative to one channel and the other set to the other channel. Hope this helps
Aug 28, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need to know if i can hook the ground or negative side together and just run the l positve and right positve with seperate wires
No. Using a search engine look for "speaker wiring" and find something that looks like what you're contemplating (which is not crystal clear). Then try to find something in the amplifier manual that blesses it. Hint: it's not there. Each speaker should have one Plus and one Minus from the same amplifier channel.
Jul 29, 2011 | Onkyo TX-SR606 Receiver
Can i wire one speaker to the other speaker inside the box so that i only have one positive and one negative cable wire coming out out of the box and to the amp
Hello... I can help you with this question. Yes it is possible to do this, but you will have to use a 2 ohm stable mono block amplifier in order to do this. By connecting both positives together and both negatives together, you will be running a 2 ohm load. So if your amp is a monoblock amp, connections will be simple as tieing all the positives together and the negatives together and just hook to the amp. If you are using a 2 channel amplifier that is bridgeable, then you will need to series the subwoofers to an 8 ohm load and then bridge the amplifier to 1 channel. The way you series the subwoofers is take the positive wire in the box and hook to the positive on subwoofer #1. Take the negative wire in the box and hook to the negative on subwoofer #2. Then take a piece of wire and hook the negative from subwoofer #1 to the positive connector on subwoofer #2. Then hook the wires to the amplifier. To bridge the amplifier (if it is a 2 channel bridgeable) would be to use the left positive and the right negative, but check the amplifier for markings to confirm this. If you have any other questions, feel free to let me know and I will help you out! Hope this helps!!
20 year car audio/video installer
Bay manager
Mar 22, 2011 | Kicker 05C104 Car Subwoofer
Hey i dont know to much about amps, but me and my friend (he knows a decent amount about amps) would plug the power into the amp and the green light would come on. Though when we plug it into the subs, the...
Are you connecting positive to positive and negative to negative from the sub to the amp? If so, try positive to positve (+) in the far left channel and then the negative to negative (-) on the far left channel to. If no luck do the same in the other channel with one sub at a time. Try one sub at a time, Dont try an connect 2 or more subs to one channel as this would cause the amp to go into protect mode (red light you describe). Usually the positive wire has either a line down the wire, writting on it or has a red seperate wire with it when wire end stripped to connect it. Hope this helps and please rate...
Mar 11, 2011 | Bazooka EL1500 Car Audio Amplifier
How to wire a 2400w amp to 3 12s subs
if the amp is a 2 channel, u could either bridge them all, or if you wanted to, you could hook 2 speakers to the two seperate channels, and then hook the other one to the negative on one channel and the possitive on the other. if this wasnt what you meant, just, try to tell me more about the amp... thanks
Dec 05, 2009 | Kicker CVR10 Car Subwoofer
What wires do i need to hook up 2 kicker solobaric s15l7 to a car
You will need the amp wires. Red Positive to battery, Black negative from amp ground to unpainted car body surface, and the blue remote wire that goes from amp to remote wire on back of cd deck.
Then you will need the rca cables from rear output of cd player to the amp.
Then just the positive and negative wire from speaker to amp. Use Speaker Positive wire to Amp Right Channel Positive
And speaker negative wire to amp Left Channel Legative wire.
That is it.
Nov 17, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I need help installing a 4 Channel Power Acoustik Amplifier to Two Pioneer Subwoofers. I hooked up the power wire to the positive battery terminal in the engine compartment. I then cut the power wire and...
You are doing right on what you described. I really like to work with a clearly described what involved in an issue.
Now we have to use a Voltmeter to check if there is power to the amplifier. If there is power to the amplifier terminal, then the problem is at the amplifier, not the connection. Let check it out:
1- Turn on your Kenwood radio, make sure to hear sound from your regular speakers.
2- Turn remote control knob to the mid level between min and max.
3- Measure the blue wire where you spliced to ground to see if you have 12V, if it is not then the problem is right there.
4- Measure the Red wire power from the Amplifier to ground ( the bolt that you connect the negative power to see if there is 12V, if not trace back to the Fuse that you inserted between the positive terminal of the battery and the wire going through the firewall to correct it.
5- If you have 12V at step 3 and 4, then you have a defect unit, return it to the manufacturer for a replacement.
Sep 06, 2009 | Car Audio & Video
Amplifier turns on but not the subwoofer?
Hello thedj3214,
You can find the color codes for a 1999 Buick Regal here. There is no dedicated amp remote wire. Neither is there a power antenna wire.
You could use the 12V "switched lead (yellow) from the radio or any switched 12V lead directly from the vehicle fuse box. I'd wire it through a dash mounted toggle switch so as to be able to turn the amp on and off manually.
The Sony 2150GSX is a 2-channel amp with the speaker terminals on either side. You do not want to ground the subwoofer itself, only the ground terminal should be connected to bare metal on the vehicle chassis or body as close to the amp as possible. The ground wire does not need to be run to the negative battery terminal.
A ground on one of the speaker leads will probably cause the amp not to power up. A ground on a speaker wire usually activates the amps protection circuit, causing it to not operate until the fault is corrected.
Hope this helps.
Jul 28, 2009 | Sony XM-2150GSX Car Audio Amplifier
Car Audio & Video Logo
94 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
